Arduino Controlled RC Car
I am planning for a project that uses Serial communications through an HC12 wireless serial module and an Arduino Uno on a RC car and controller. I have written some code and I would like some more eyes to look it over and point out any problems. I am gonna use the following code for the Arduino on the Car(receiver)
#include <SoftwareSerial.h>
#include <Servo.h>
#define relay 8
#define ESC 9
Servo steering;
SoftwareSerial HC12(2,3);
    HC12.begin(9600);
    steering.attach(10);
    steering.write(90);
    delay(100);
   if(HC12.available()>0){
     char val=HC12.read();
     switch (val){
       case 'a':
         analogWrite(ESC,250);
         digitalWrite(relay, HIGH);
       case 'b':
         analogWrite(ESC, 204);
       case 'c':
         analogWrite(ESC,153);
         digitalWrite(relay,HIGH);
       case 'd':
         analogWrite(ESC,102);
       case 'e':
         analogWrite(ESC,51);
       case 'f':
         analogWrite(ESC,0);
         digitalWrite(relay,LOW);
       case 'g':
       case 'h':
       case 'i':
       case 'j':
         analogWrite(ESC,204);
       case 'k':
         analogWrite(ESC,255);
       case 'l':
         steering.write(0);
       case 'm':
         steering.write(25);
       case 'n':
         steering.write(50);
       case 'o':
         steering.write(75);
       case 'p':
         steering.write(100);
       case 'q':
         steering.write(125);
       case 'r':
         steering.write(150);
And the following code for the controller(sender)
#define xpin 4
#define ypin 5
    HC12.begin(9600);
    int val1=analogRead(xpin);
    int val2=analogRead(ypin);
    int xval=map(val1,0,1023,-3,3);
    int yval=map(val2,0,1023,-5,5);
    switch(xval){
      case -3:
        HC12.write('l');
      case -2:
        HC12.write('m');
      case -1:
        HC12.write('n');
      case 0:
        HC12.write('o');
      case 1:
        HC12.write('p');
      case 2:
        HC12.write('q');
      case 3:
        HC12.write('r');
    switch(yval){
      case -5:
        HC12.write('a');
      case -4:
        HC12.write('b');
      case -3:
        HC12.write('c');
      case -2:
        HC12.write('d');
      case -1:
        HC12.write('e');
      case 0:
        HC12.write('f');
      case 1:
        HC12.write('g');
      case 2:
      HC12.write('h');
      case 3:
        HC12.write('i');
      case 4:
        HC12.write('j');
      case 5:
        HC12.write('k');
    delay(100);
    Serial.println(millis());
The RC car already has a steering servo and a motor that I am planning on driving with a homemade h bridge motor driver(that is why there is a analog.Write to the the electronics speed controller or ESC, that will be my motor driver). Let me know what you think. Thanks!
Rather than us wander though your code, tell us what doesn't work.
Paul
