Arduino controlling 2.4GHz R/C Helicopter
Hey guys, I am a software developer by trade and I'm trying to earn my hardware hacking merit badge :wink:
Please talk to me like I'm totally ignorant. :slight_smile: The last electronics project I did was building a TV transmitter from a kit with my dad (and I helped!), and that was years ago.
I am attempting to connect an Arduino to a 2.4GHz R/C controller for a sick co-axial helicopter I have. It is important to note that this helicopter features a 4 channel controller (Throttle, Yaw, Pitch, Roll). I cracked this baby open and (no big surprise) found 4 potentiometers. I grabbed my volt meter and played around with each. From testing the middle (wiper?) pin I was able to determine that the voltage to these pots ranges from 0 to 4v. Using analogRead with the Arduino I am able to detect the position of the joysticks and their potentiometers pretty reliably.
However, I would now like to supply power from the Arduino to each pot and bypass the sticks to allow controlling the Heli from the Arduino. I tapped in to the middle pin on the throttle and things work semi-ok using analogWrite; However the rotors have a kind of pulsing effect I am curious if this is due to the PWM. I have also run in to another issue where the right joystick has springs on it that keep it centered. This means that the pot sits at about 2v, if I send 4v from the Arduino, wouldn't that total 6v and cause problems? I am thinking I might need to short-circuit the pot's positive pin to the pot's ground pin, but that feels dirty. Ideally any modifications I make to the transmitter would not prevent it from working in the future. So far all I have done is tapped in to the wiper pins on the pot and run wires outside the transmitter.
My Questions (TL;DR)
  • Is the effect of the PWM noticeable when using analogWrite as a potentiometer?
  • Is there an easy way to short circuit a pot and reset it's voltage to 0?
AnalogWrite does not output an analog voltage - it outputs a voltage which switches between 0V and 5V. This is not suitable as input to a circuit which is expecting to read a potentiometer value.
You could use a hardware smoothing circuit to convert the Arduino's output pulses to a true analog voltage, or use a digital-to-analog converter to do the job properly.
Thanks for your response. As I said, I'm still pretty new to most of this.
Does this describe what you are suggesting? http://provideyourown.com/2011/analogwrite-convert-pwm-to-voltage/
Yes that page looks pretty good.
Where would the extra 2V come from?
Hi, Here's another How-To on Analog Output:
http://arduino-info.wikispaces.com/Analog-Output
