Hello, I just began learning arduino and I just want to make a simple count down timer with a single push button with a start/restart function. I successfully managed to start and restart the timer and display it to the lcd but after the timer completes, it automatically restarts and begins to count down. I do not currently know what is causing the loop, I tried changing my count value after completion but it doesn't help.
Here is my code. Thank you.
#include <LiquidCrystal.h>
#include "Countimer.h"
Countimer tDown;
Countimer tNone;
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
int switchPin = 8;
int ledPin = 13;
int count = 0;
boolean lastButton = LOW;
boolean ledon = false;
boolean currentbutton = LOW;
pinMode (switchPin, INPUT);
pinMode (ledPin, OUTPUT);
// Count-down timer with 21s
tDown.setCounter(0, 0, 10, tDown.COUNT_DOWN, tDownComplete);
// Call print_time2() method every 1s.
tDown.setInterval(print_time2, 1000);
// No counter
// Just call print_none() method every 2s.
// tNone.setInterval(print_none, 2000);
boolean debounce(boolean last)
boolean current = digitalRead(switchPin);
if (last != current)
delay (5);
return current;
tDown.run();
// tNone.run();
currentbutton = debounce(lastButton);
if (lastButton == LOW && currentbutton == HIGH)
ledon = !ledon;
lastButton = currentbutton;
if (ledon == true)
count = 1;
count = 0;
switch(count)
case 0:
tDown.stop();
// lcd.clear();
print_time2();
// tNone.stop();
case 1:
tDown.start();
// tNone.start();
default:
void print_time2()
Serial.print("tDown: ");
Serial.println(tDown.getCurrentTime());
lcd.clear();
lcd.print("Time: ");
lcd.print(tDown.getCurrentTime());
//void print_none()
// Serial.print("tNone: millis(): ");
// Serial.println(millis());
void tDownComplete()
lcd.clear();
lcd.print("COMPLETE!!");
Serial.println(count);
