arduino countdown timer
Hi
i have a big problem and i am stuck in how to fix it. i am creating a countdown timer which starts from 24 seconds and countdown to 0, this countdown timer also includes a single digit for milliseconds. the milliseconds count upwards from 0 to 10 then back to 0 and so on, once it hits zero the seconds go down by one. the digits look like this ( 24.0 ), 24 being the seconds and 0 being the milliseconds. my code works as it counts down the right way, however the numbers stop at 1.9 and never reaches 0.0. I have added a delay as there will be a buzzer going off for two seconds before the reset happens automatically. over all the timer is not reaching 0.0 but counts down the right way.
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#ifndef PSTR
 #define PSTR
#endif
#define PIN 6
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(32, 8, PIN,
  NEO_MATRIX_TOP     +  NEO_MATRIX_LEFT +
  NEO_MATRIX_COLUMNS + NEO_MATRIX_ZIGZAG,
  NEO_GRB            + NEO_KHZ800);
const uint16_t colors[] = {
  matrix.Color(255, 255, 0) , matrix.Color(255, 255, 0), matrix.Color(255, 255, 0) };
  const int buttonPin = 2;     // the number of the pushbutton pin
int buttonState = 0;
int ms1 = 0;
int s = 24;
int validate = 0;
//String s_string = "";
int button_check = 0;
int check = 0;
int ledPin = 11;
  matrix.begin();
  matrix.setTextWrap(false);
  matrix.setBrightness(40);
  matrix.setTextColor(colors[0]);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT_PULLUP);
   pinMode(ledPin, OUTPUT);
int x    = matrix.width();
int pass = 0;
buttonState = digitalRead(buttonPin);
///////////////////////////////////////////////////////////////////////////////////////////////////// push is LOW
if (button_check == 0){
if (buttonState == HIGH) {
   // digitalWrite(ledPin, HIGH);
    check = 0;
validate = 1;
 if (buttonState == LOW) {
   button_check = 1;
   check = 1;
validate = 0;
if (check == 1){
  ms1++;
  if(ms1 == 10){
    ms1 = 0;
    s--;
    if(s == 0 && ms1 == 0){
      check = 0;
      s = 0;
      ms1 = 0;
      delay(2000);
      digitalWrite(ledPin, LOW);
      validate = 1;
  if(validate == 1){
    button_check = 0;
    ms1 = 0;
    s = 24;
String ms1_string = String(ms1);
//String ms2_string = String(ms2);
String s_string = String(s);
//String s2_string = String(s2);
  matrix.fillScreen(0);
  matrix.setCursor(4, 0);
  matrix.print(s_string +  "." + ms1_string);
  if(--x < -36) {
    x = matrix.width();
    if(++pass >= 3) pass = 0;
    matrix.setTextColor(colors[pass]);
  matrix.show();
  delay(100);
Get rid of delay()s as they stop the sketch from running for this time period.
Why didn't you use millis() in this sketch (as in BlinkWithoutDelay BWD)?
24.0 Where 0 is 100ms or 1/10th of a second :wink:
You should always incorporate switch debouncing to handle switch reads.
