Arduino (Counter as a Dead man Switch)
Hi PaulS
Thanks for your answer,
Sorry for the delay but I was out on the road for a job so I didn't had the
chance to spent time in front of my computer.
I did some tests this morning and I'm not sure how to fully implement your suggestion.
I wante to show you what I did and please, try not to laugh to much because like I said, I'm a newbie.
This is at the beginning of my code for the initialization.
  bool goingUp = true;
  static int currPress;
  static int prevPress = 0;
This is the fonction section
bool pressureIncreasing()
   currPress = PSI;
   if(currPress <= prevPress)
   goingUp = false;
   Serial.println (currPress); // I add the 3 next lines to see if the value were ok
   Serial.println("    ");
   Serial.println (prevPress);
   prevPress = currPress;
   return goingUp;
   if (goingUp = false)
   stateRELAY1 = LOW;
And in my Loop at the end I added the section's name with all the other I have.
I try to put only the name of each fonction in the loop so I can take them out
for troubleshooting when I need.
void loop(){
pressureIncreasing();
For now it's not working, I can see the values in the Serial.print with the 3 lines I added
but that's it.
I have no error message so far but no results also :slight_smile:
What can you tell me from here ?
Thanks
My goal will be to tell the code:
If the Pressure (PSI) did not increase by 25PSI in the last 3 minutes, close the compressor (stateRELAY1).
