Arduino counter with OLED
Hello. Im fairly new to arduino, but finished my project not too long ago. Right now im trying to make a counter that goes down by 1 number each time a button is pressed. Ive got the code right without any errors, yet it doesnt seem to work. I press the button but nothing happens. I tried playing around with different pins, LOWS and HIGHS, etc.
here’s my code:
#include <OLED_I2C.h>
#include <Button.h>
OLED myOLED(SDA, SCL, 8 );
int increasebutton = 4;
int buttonstate;
int lastbuttonstate = LOW;
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 10;
extern uint8_t SmallFont;
extern uint8_t BigNumbers;
int value = 25;
void setup(){
myOLED.begin();
myOLED.setFont(BigNumbers);
pinMode(increasebutton,INPUT_PULLUP);
increaseParameter();
myOLED.printNumI(value,CENTER,24);
myOLED.update();
myOLED.clrScr();
void increaseParameter()
int reading = digitalRead(increasebutton);
if (reading != lastbuttonstate) {
lastDebounceTime = millis();
if((millis() - lastDebounceTime) > debounceDelay) {
if(reading != buttonstate){
buttonstate = reading;
if(buttonstate == HIGH) {
value–;
whenever there is a change in button state you reset lastDebounceTime.
you should reset lastDebounceTime only inside the condition when > denounceDelay AND there is a button state change
gcjr:
so what should i change up? could you fix the code? sorry, im a visual learner, and due to me being new to arduino, its hard for me to understand what exactly i have to do.
I tried to fix it. What else is lacking??
#include <Button.h>
const int decreasebutton = 4;
int buttonstate;
int value = 25;
void setup(){
myOLED.begin();
pinMode(decreasebutton,INPUT_PULLUP);
decreaseParameter();
myOLED.update();
myOLED.clrScr();
void decreaseParameter()
int reading = digitalRead(decreasebutton);
if((millis() - lastDebounceTime) > debounceDelay && buttonstate == HIGH) {
value–;
lastbuttonstate = reading;
dainyzas:
very good. you tried
                value--;
gcjr:
               value–;
Thank you, sadly the number still doesnt go down. could you please check it over again? ^^’
#include <Button.h>
int buttonstate;
int value = 25;
void setup(){
myOLED.begin();
myOLED.update();
myOLED.clrScr();
value–;
this is the problem i fixed
Thank you! It works now!
