Arduino crashes after removing boards from /hardware
Hello,
The Arduino IDE aborts launching after I defined some boards variants in the /hardware folder and removed them.
Here is what I did
  • Added new variants in the /hardware folder
  • The variant was listed but an error showed at compilation "Error resolving FQBN: getting"
  • So I removed the files in /hardware
  • Then the Arduino IDE does not launch
It seems Arduino still has a reference to these boards but pointing to nothing. The debug shows
TRACE StatusLogger Using default SystemClock for timestamps.
DEBUG StatusLogger org.apache.logging.log4j.core.util.SystemClock does not support precise timestamps.
TRACE StatusLogger Using DummyNanoClock for nanosecond timestamps.
DEBUG StatusLogger Reconfiguration complete for context[name=1e6f5c3] at URI jar:file:/C:/Program%20Files%20(x86)/Arduino/lib/pde.jar!/log4j2.xml (org.apache.logging.log4j.core.LoggerContext@f2bbc1) with optional ClassLoader: null
DEBUG StatusLogger Shutdown hook enabled. Registering a new one.
DEBUG StatusLogger LoggerContext[name=1e6f5c3, org.apache.logging.log4j.core.LoggerContext@f2bbc1] started OK.
Preparing boards...
java.lang.NullPointerException
at processing.app.Base.rebuildProgrammerMenu(Base.java:1705)
at processing.app.Base.(Base.java:286)
at processing.app.Base.main(Base.java:150)
How can I fix this?
