I wrote a Version of the classic QBASIC Gorillas for the Arduino Uno using the TVOut library.
Everything worked fine until I changed the code to reinitialize after a player has won the game
so that the next round could start.
The program does start a new round, draws the new city and the players,
waits for the input of Angle and Speed and as soon as the player confirms the Speed the Uno crashes.
So I thought that I forgot to reinitialize some global variables and added "Serial.Begin(9600);" to the Setup() function in order to check my variables and debug the sketch.
And the problem disappeared... :o
I changed NOTHING except adding "Serial.Begin(9600);"!
There is not a single call to any other Serial methods and yet the bug is gone and the game works perfectly fine.
And if I remove "Serial.Begin()" the bug is there again...
Any advice, ideas or suggestions would be much appreciated!
Just that different data gets clobbered. One really nasty thing is that local variables are created on the stack. depending on the arduino stack frame, return addresses might go there too, and get wiped out by your off-by-one error.
Allright, I think I figured out what the real problem is.
The Arduino Reference says the following:
" Note that when declaring an array of type char, one more element than your initialization is required, to hold the required null character. "
Is it possible that this also applies to arrays of type byte?
Because when I increased the size of my byte array by one and didn't initialize it's last element it all worked fine.
Besides that they are both 8 Bit variables, "byte" is just the unsigned version of "char" right?
If thats the case, I think this should be added to the reference because it is confusing for newbs like myself and can introduce some really nasty bugs.
Making it global turned out to be a red hering because it just changed the random garbage that occured when trying to read or initialize the null character.
redeagle:
Is there a difference between local and global variables when it comes to filling arrays?
There are two main differences between 'global' and 'local' variables: Initialization and lifetime.
'global' variables:
are initialized to zeros at start of the programm automatically (if not initialized different)
are living all the time while the program is executing
'local' variables:
are NOT initialized to zeros at start of the function automatically
will have pure random contents at start of the function (if not initialized different)
are only living while the function is executing
So non-initialized 'local' variables may have a pure random contents each time the function is entered. And these variables do not use RAM all the time, but only while the function is running. And the lifetime of such 'local' variables is limited to the execution time of the function: Function finished ==> local variable vanished. So if you set local variables to some value, finish the function and call the same function again later, the local variables will NOT have kept their values, but the values may have changed randomly.
redeagle:
No, it does not apply to byte arrays and it even not apply to every char array. It only applies to char arrays that are to be used as 'string' and with the AVR LIBC string functions. C-strings will have a finalizing null character at the end, they are nullterminated strings. So the string "Hi" will need 3 characters: 'H', 'i' and '\0'.
The problem was obviously caused by my weird drawing algorythm, which only works if the number of the building is bigger than zero and therefore requires an array that is bigger by one than the actual number of buildings since arrays are zero indexed... facepalm
Please excuse the extent of my stupidity!
If you never played Gorillas and have a hard time imagening what I mean by "building" or "city",
the image generated by this code looks like that:
The height of the buildings is generated randomly every new round...
Next time I'll check my code twice before wasting everyone's precious time!
And if I get really desperate I will post the code immediately and wont try to describe the problem in general terms.
