hi everyone Im new in forum. I have a problem with CRC. I found a CRC-16 XModem library for arduino. I want to re-compile for CRC-16 Modbus. I tried many time but it did not work. Anyone help me ?
// CRC16 support class
// Based on various examples found on the web
// Copyright (C) 2014 Vincenzo Mennella (see license.txt)
// History
// 0.1.0 31/05/2014: First public code release
// 0.1.1 17/12/2014: Minor revision and commented code
// License
// "MIT Open Source Software License":
// Permission is hereby granted, free of charge, to any person obtaining a copy of
// this software and associated documentation files (the "Software"), to deal in the
// Software without restriction, including without limitation the rights to use, copy,
// modify, merge, publish, distribute, sublicense, and/or sell copies of the Software,
// and to permit persons to whom the Software is furnished to do so, subject to
// the following conditions:
// The above copyright notice and this permission notice shall be included in all
// copies or substantial portions of the Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
// IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
// FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
// COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
// IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION
// WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#ifndef CRC16_H
#define CRC16_H
#define LIBRARY_VERSION_CRC16_H "0.1.1"
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
class Crc16 {
private:
//Crc parameters
uint16_t _msbMask;
uint16_t _mask;
uint16_t _xorIn;
uint16_t _xorOut;
uint16_t _polynomial;
uint8_t _reflectIn;
uint8_t _reflectOut;
//Crc value
uint16_t _crc;
uint8_t reflect(uint8_t data, uint8_t bits = 32);
public:
inline Crc16()
//Default to XModem parameters
_reflectIn = false;
_reflectOut = false;
_polynomial = 0x1021;
_xorIn = 0x0000;
_xorOut = 0x0000;
_msbMask = 0x8000;
_mask = 0xFFFF;
inline Crc16(uint8_t reflectIn, uint8_t reflectOut, uint16_t polynomial, uint16_t xorIn, uint16_t xorOut, uint16_t msbMask, uint16_t mask)
_reflectIn = reflectIn;
_reflectOut = reflectOut;
_polynomial = polynomial;
_xorIn = xorIn;
_xorOut = xorOut;
_msbMask = msbMask;
_mask = mask;
void clearCrc();
void updateCrc(uint8_t data);
uint16_t getCrc();
unsigned int fastCrc(uint8_t data[], uint8_t start, uint16_t length, uint8_t reflectIn, uint8_t reflectOut, uint16_t polynomial, uint16_t xorIn, uint16_t xorOut, uint16_t msbMask, uint16_t mask);
inline unsigned int XModemCrc(uint8_t data[], uint8_t start, uint16_t length)
// XModem parameters: poly=0x1021 init=0x0000 refin=false refout=false xorout=0x0000
return fastCrc(data, start, length, false, false, 0x1021, 0x0000, 0x0000, 0x8000, 0xffff);
// Initialize crc calculation
void Crc16::clearCrc()
_crc = _xorIn;
// Update crc with new data
void Crc16::updateCrc(uint8_t data)
if (_reflectIn != 0)
data = (uint8_t) reflect(data, 8);
int j = 0x80;
while (j > 0)
uint16_t bit = (uint16_t)(_crc & _msbMask);
_crc <<= 1;
if ((data & j) != 0)
bit = (uint16_t)(bit ^ _msbMask);
if (bit != 0)
_crc ^= _polynomial;
j >>= 1;
// Get final crc value
uint16_t Crc16::getCrc()
if (_reflectOut != 0)
_crc = (unsigned int)((reflect(_crc) ^ _xorOut) & _mask);
return _crc;
// Calculate generic crc code on data array
// Examples of crc 16:
// Kermit: width=16 poly=0x1021 init=0x0000 refin=true refout=true xorout=0x0000 check=0x2189
// Modbus: width=16 poly=0x8005 init=0xffff refin=true refout=true xorout=0x0000 check=0x4b37
// XModem: width=16 poly=0x1021 init=0x0000 refin=false refout=false xorout=0x0000 check=0x31c3
// CCITT-False: width=16 poly=0x1021 init=0xffff refin=false refout=false xorout=0x0000 check=0x29b1
unsigned int Crc16::fastCrc(uint8_t data[], uint8_t start, uint16_t length, uint8_t reflectIn, uint8_t reflectOut, uint16_t polynomial, uint16_t xorIn, uint16_t xorOut, uint16_t msbMask, uint16_t mask)
unsigned int crc = xorIn;
int j;
uint8_t c;
unsigned int bit;
if (length == 0) return crc;
for (int i = start; i < (start + length); i++)
c = data[i];
if (reflectIn != 0)
c = (uint8_t) reflect(c, 8);
j = 0x80;
while (j > 0)
bit = (unsigned int)(crc & msbMask);
crc <<= 1;
if ((c & j) != 0)
bit = (unsigned int)(bit ^ msbMask);
if (bit != 0)
crc ^= polynomial;
j >>= 1;
if (reflectOut != 0)
crc = (unsigned int)((reflect(crc) ^ xorOut) & mask);
return crc;
// Reflects bit in a uint8_t
uint8_t Crc16::reflect(uint8_t data, uint8_t bits)
unsigned long reflection = 0x00000000;
// Reflect the data about the center bit.
for (uint8_t bit = 0; bit < bits; bit++)
// If the LSB bit is set, set the reflection of it.
if ((data & 0x01) != 0)
reflection |= (unsigned long)(1 << ((bits - 1) - bit));
data = (uint8_t)(data >> 1);
return reflection;
#endif
