arduino-create-agent 1.1 Silent Install
Looking at getting the web console working at school. Tried to silently install with the switches --unattendedmodeui minimalWithDialogs --mode win32 unattended. The installer doesn't like the win32 unattended value. Anyone silently installed the arduino-create-agent?
That one will have to wait until monday but I will post it in a way they see it first thing.
Did you set a script to answer YES to the questions the normal install would pose ?
Answer here
"Did you set a script to answer YES to the questions the normal install would pose ?"
No, that's what the switches are for, aren't they?
Hi
Did you get the results you wanted from smellai's answer.
No, install still failing. Has anyone installed this product in an enterprise environment?
The switch --mode unattended works. Still an issue with a self-signed certificate prompt box.
Error running C:\Users\cpalmer34\AppData\Roaming/ArduinoCreateAgent-1.1/certmgr.exe -add "C:\Users\cpalmer34\AppData\Roaming/ArduinoCreateAgent-1.1/ca.cert.cer" -s -r currentUser root: child killed: unknown signal
This is the error I get trying to silently install
