Arduino Create Plugin Error
When I try to install the Arduino Create plugin on my computer I get this error:
There has been an error. Error trying to install file: destination ${windows_folder_startup} resolved to an empty value The application will exit now.
Some files were still installed and I managed to start the plugin. Arduino Create said it detected the plugin but after that it says this:
We are not able to establish a secure (HTTPS) connection between the Plugin and the Arduino Web Editor.
Any ideas?
Which version of windows are you using?
Added an issue to our repo https://github.com/arduino/arduino-create-agent/issues/118, seems that another user have the same problem: http://forum.arduino.cc/index.php?topic=415177.0
matteosuppo: Which version of windows are you using?
I am using Windows Vista Home Premium 64 bit
Hey @Isaac100, do you still have this issue? If so could you share some screenshot or even better a screencast? It is a bit hard for us to do extensive testing on all the Windows version so your help will be really valuable. Thanks!
@00alis, Yes I still have this issue and I am working on making a screen-cast for you.
@00alis, here is a link for the screencast of the issue:
https://drive.google.com/open?id=0Bxqil19Xq4ecb1RySFd2bWtGa0E
Thank you so much for the screencast, we will send feedback soon (as Chrome is not supporting Windows XP and Vista anymore it is a bit hard for us to follow this specific issue). Thank you for your patience!
@00alis, just checking in, any advances on the issue?
Hello, the same problem here, on windows 7 professional 64bits. Solution??
Hi we are working on a new release of the Plugin, it would be really great if you could install the development version and let us know if it fixes your issues http://downloads.arduino.cc/CreateBridge/staging/ArduinoCreateAgent-1.0-windows-installer.exe
Please remember to reinstall the plugin from the Getting Started flow after a while, so you can get all the updates that we will publish.
Any solution yet on this issue? Getting the same error on my Widows 7 32-Bit.
“There has been an error.
The application will exit now.”
Hi @abe_ignacio,
that problem seems to be caused by the absence of Windows Startup folder. This workaround looks quite promising in recovering the startup folder functionality. Could you try applying that fix? Thanks
Still the same problem. Windows 10 Enterprise. Runned as administrator. I try the solution from post above but, unfortunately, it's company laptop. Do you have any idea how to solve it?
Regards from Poland.
@panunderhill
With a "company" laptop you would have to talk directly to your IT team to allow the CREATE software and the required ports.
Sorry for the answer but it would not be good practice to tell you how to defeat a companies security protocols.
Bob.
