Hi there,
So here's the story..... I'm in the process of building a Automatic generator controller. For this to work correctly I need to supply the Arduino with as correct a possible Voltage and Current value.
Voltage input is sorted and I'm fairly happy with its accuracy, using a 240-6V transformer, then rectifying to a suitable DC range.
Now the part where I'm not sure what is the best option.
I'm using a 100A-50mA Current Clamp. Since the analog inputs on the Arduino works by supplying a 0-5VDC input, I have to convert the 50mA output from the Current clamp to a 0-5VDC measurable value.
I've browsed the internet and all I could find was attached circuit "Capture".
Why can't I use a the a 130Ohm resistor in parallel with the sensor, This will cause a 6.522V potential to be created which I would then Rectify and Filter to give my Arduino a 5V input at 100A primary on the clamp?
I have attached a test circuit diagram "Circuit 2" which I ran on LT Spice.. Has anyone used a current clamp as such yet? and how was the accuracy?
Thanks for reading
