arduino daisy chain
I am attempting a hardware setup of this type:
I have attached the grounds on the two arduino boards to each other.
The xbees can send data fine, but it appears the second arduino in the chain is not outputing to the serial at all.
I assume the problem is in the code, but it is not obvious to me. Any advice would be much appreciated!
Code of first 'sender' arduino:
// Sender:
int analogValue0, val0;
// Serial port enable
// read analog pin 0
analogValue0 = analogRead(0);
// send the value to the serial port
Serial.println(analogValue0, DEC);
Code of second 'receiver' arduino:
// RECIEVER
int incomingByte;
// if there is bytes available coming from the serial port
if (Serial.available()) {
// set the values to the 'incomingByte' variable
incomingByte = Serial.read();
Serial.println(incomingByte, DEC);
Did you connect the ground from the second Arduino to the ground on the Xbee module ?
If not you should.
Why this method instead of I2C? Just curious... :slight_smile:
@MikMo: Thanks for your message, the xbee ground is connected to the second arduino. I have tested the xbee part of the set-up and it appears to be working.
Hi cr0sh, that is a good question. The reason is that once I have this setup working I am going to replace the first arduino in the chain with this:
It has a ATmega168 on board, and code can be uploaded to it via the arduino IDE. Rx/Tx appears to be the only form of communication available on this board.
Did you test the output from the serial on the second board with the serial monitor just to make sure its putting out any data.
Then do the same with the first board to make find the spot where data is noi longer coming throug.
@Mikmo: thanks for your message. I tested all the connections as you suggested and they are working as expected. I rearranged the power supply (so both boards are powered from the same battery), and I think this was the trick for being able to receive the first board's input.
I also had to change the receiving board's code:
// RECIEVER
int incomingByte1, incomingByte2, incomingByte3, incomingByte4, incomingByte5;
if (Serial.available() > 0) {
incomingByte1 = Serial.read();
incomingByte2 = Serial.read();
incomingByte3 = Serial.read();
incomingByte4 = Serial.read();
incomingByte5 = Serial.read();
Serial.print(char(incomingByte1));
Serial.print(char(incomingByte2));
Serial.print(char(incomingByte3));
Serial.print(" ");
Serial.println(analogRead(0), DEC);
These changes were required because the serial.read command is outputting the three digits of the original int in three bytes and two formatting characters. It seems that the formatting characters need to be read from the serial buffer or the whole sequence gets mixed up.
So, if Serial.available() reports that there are 3 bytes to be read, it's OK to read all 5, right?
