arduino dc motor ic
What is the the best chip like l239d , sn471 or other for interfacing dc motor with arduino.
Do you know any good tutorial for interfacing dc motor.
Do I need to use any other component with the dc drive IC like diodes,resistors.
thanks
Here m8, this is the tutorial I learned from, goes over both wiring, code, and teaches you both how to do direction and speed of motor as well:
http://itp.nyu.edu/physcomp/Labs/DCMotorControl
the dc IC's are usually referred to as H-Bridges and the L293NE or SN754410 are interchangeable (i dunno if there are any more variations, probably, but these are the ones I have used and also the only ones I ahve run into)
I drive my DC (12V) motors by simple MOSFETs, as I don't need to change the direction. See here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1230677423
and I don't even use a 2K pull-down resitor and it works well...
interesting... speaking about size, how big is the usual mosfet to motor setup (just the circuitry, no arduino, no motor), cause the h bridges are fairly small, although the set up is needed, so thats a minor minus unless you are happy to do the extra work
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
Can I use l293d or l293e instead of the 2 ics you suggested.I want a interface it with small dc motor from a toy car.
thanks
my link will work best for you...
