Arduino Dead USB port, looking for programing arduino through pins
I looking for programing arduino through pins
one capacitor from my arduino nano just burn, so i can't turn on or program arduino by usb but it still working if i power on by Vin pin
I would like to know if it is posible to upload programs to arduino using a USB/FTDI board to Arduino pins
So i guess the only missing pin i need to conect is DTR pin in arduino
Have any of you this problem before?
cheers
Then connect any USB/Serial adapter to D0, D1, +5, Gnd, and its DTR pin thru a 100nF cap to the reset pin.
You may have to remove the two resistors that connect the 16U2 Rx/Tx output to the D0/D1 pins.
Can you ID the capacitor that failed? And perhaps see any possible causes or reasons for failure.
i tried but it don't respond, even i tried with a working arduino nano but also get:
avrdude: stk500_getsync(): not in sync: resp=0x00
then i tried connect an arduino uno board with atmega removed to an arduino nano (reset tx rx 5v gnd) but again get same "no sync error"
do i missing something??
the only thing i didn't ID is the resistences from TX and RX to remove, is it mandatary??
thanks for all the help you bring me and thanks for the effort you do to understand my english
If the onboard USB/Serial chip has its outputs hung up in some state that prevents the Rx/Tx lines from working, removing the two resistors may be needed.
They are part of RN4, an 8-pin, 4 resistor package.
You can remove it, and then put a 1K resistor across pins 4-5 for the Power LED.
Are you sure you didn't fry the '328P chip also? What were you doing when the capacitor burned?
