Arduino debounce button with delay
I’m having a bit of trouble with my Arduino when I try and use long wires to a switch.
If I use a shorter wire I have no problems, but as soon as they are extended, things start playing up.
What I’m trying to do is, when I press a button I would like it to output to a pin, stay on for 2 seconds, then turn off regardless whether the button is still pressed or not.
The code I use at the moment that does work with short wires is:
// constants won't change. They're used here
// to set pin numbers:
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  10;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
 // initialize the LED pin as an output:
 pinMode(ledPin, OUTPUT);
 // initialize the pushbutton pin as an input:
 pinMode(buttonPin, INPUT);
 // read the state of the pushbutton value:
 buttonState = digitalRead(buttonPin);
 // check if the pushbutton is pressed.
 // if it is, the buttonState is HIGH:
 if (buttonState == HIGH) {
   // turn LED on:
   digitalWrite(ledPin, HIGH);
   delay(2000); // wait for a second
   digitalWrite(ledPin, LOW);
I’ve been reading on forums that using debounce may solve this problem. However I’m new to Arduino and not sure how to implement this.
I used the Arduino button tutorial and used a 10k pull down resistor as stated. Is there any way I can allow, either with code or with a resistor / cap, to trigger via a switch that has a wire length of <2m?
Any help appreciated.
So you have a code that works at short distances but does not work with long ones. That means the is nothing wrong with your code but your hardware is at fault.
Unfortunately you have told us very little about this so there is little we can do to help but guess.
See our problem?
I the mean time read this:-
http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
And try wiring your switches between input and ground.
Please read this:-
How to use this forum
Because your post is breaking the rules about posting code.
A hardware solution might be to connect a 1uF capacitor in parallel with your 10K pulldown resistor. Then connect a 1K resistor in series with your pushbutton to the input.
Grumpy Mike.
Thanks for the link. That's has solved the problem of the long wires.
I have one more problem. I need the output to turn off after 2 seconds regardless if the button is still pressed.
At the moment if I momentarily switch the code works. If I keep the switch closed the output stays constant. I need the out put to turn off even if the button is still pressed.
What am I missing?
Skella:
What am I missing?
Code tags,
as suggested by Mike. You could edit your first post and add them, using the </> button in the “Edit” window.
Sorry. I've added the code tags.
What is needed is a Timing sequence
unsigned long startTime = 0;
const long interval = 1000;  // 1 second = 1000 millis
bool timeFlag = false;
  if (something you want to Time)
    timeFlag = true;
    startTime = millis();    // Begin timing sequence
    // do stuff here when timing sequence starts
  unsigned long currentTime = millis();
  if (timeFlag == true && currentTime - startTime >= interval) // End timing sequence
    timeFlag = false;
    // do stuff here when time is up
Skella:
Thanks for that. You've made an old man very happy. :smiley:
Thank you for the code example Hutkikz
So ive tried to use the exmple you gave me with the code i already had and what i intend to do. Have i done this right and will it work?
const long interval = 2000;  // 1 second = 1000 millis
  if (buttonState == HIGH);
    timeFlag = true;
    timeFlag = false;
Sorry for sounding like a complete newbie but we all have to start somewhere.
 if (buttonState == HIGH); //<<<<<Remove this semi-colon
    timeFlag = true;
except for the extra semi-colon it looks good.
I just remembered that you also wanted to debounce the button.
That code is only for timing.
this example adds a simple debounce also.
Note that I used INPUT_PULLUP so the button is connected to the pin and ground and the logic is reversed(LOW(0) when pressed and HIGH(1) when NOT pressed
// Connect Button between pin and ground
const byte button = 5; // choose your pin
// timing variables
  // Set Button to Input and Enable Built in Pull up Resistor
  pinMode (button, INPUT_PULLUP);
  bool buttonPressed = checkButton();
  if (buttonPressed)
    timeFlag = true;
    timeFlag = false;
bool checkButton()   // Function to read button and Debounce it
  static unsigned int buttonCount = 0;
  bool buttonState;
  bool buttonRead = digitalRead(button);
  if (buttonRead == 0) // the button was pressed
    buttonCount++;  // increment the counter
  else   // if the button bounced
    buttonCount = 0;  // reset the counter
         // if we get x number of consecutive positive reads
  if (buttonCount == 10) // This is what adjusts sensitivity
    buttonState = true; // we accept this as a good button press
    buttonState = false;  // we do not accept this as a good button press
  return buttonState;
Thank you. I will go and give that a try now.
I made a mistake in the debounce code which is now corrected.
Hope it didn't mess you up.
Thank you for the support.
So this is working, but only the same as before.
This is my code :
const byte button = 2; // choose your pin
const int ledPin =  13;      // the number of the LED pin
// timing variables
  if (buttonPressed)
    timeFlag = true;
    timeFlag = false;
  bool buttonState;
  return buttonState;
If the button remains pressed the led just stays lit and does not go off after 2 seconds. If i i just press the button it works, its only when i keep my finger on it that it stays lit.
This is for a semi automated bottle capping machine. I place a bottle against a stop which in turn engages a switch, that switch then outputs from pin 13 to a pneumatic solenoid that activates a pneumatic actuator that extends down to cap the bottle. It takes 2 seconds to tighten the cap after that point pin 13 needs to switch off to deactivate the solenoid and return the actuator to its original position so i can remove the bottle, only when i remove the bottle will the switch be 'un pressed' and ready for the next bottle to start the sequence again.
As it stands if i place a bottle in because the switch is contstantly pressed the actuator remains to be extended and never returns after 2 seconds so i am unable to remove the bottle.
The output from pin 13 drives a mosfet to switch the power to the solenoid.
Try this.
it should keep the sequence from restarting until after the sequence is complete.
if (buttonPressed && timeFlag == false)
    timeFlag = true;
edit:
If the button is still pressed after the timing expires it will restart immediately.
In that case you will need to detect when the button is released(modify the checkbutton function) and add code to deal with that.
unfortunately I need to go to work and so will not be able to help further till after
Hutkikz you have been a life saver :slight_smile:
i Added a 5 second timer and now i have seconds to remove the bottle
this is the code for anyone else who might have this problem
// timing variables
const long interval2 = 5000;
unsigned long currentTime2 = millis();
  if (buttonPressed && timeFlag == false && currentTime2 - startTime >= interval2)
    timeFlag = true;
    timeFlag = false;
  bool buttonState;
  return buttonState;
however i am having one small problem. when i power the arduino up using the usb cable things work perfect. when i remove the usb and power the board with a 12v supply when i press the button it works as intended but when the button hes been released the code continues to loop. it comes on for 2 seconds, goes off for 5 then back on for 2 and so on.
what can cause this by runnin the board on the 12v power supply?
really quick as I leave.
2nd startTime and timeFlag also
