Please, you must show us your complete sketch. Attach your code using the </> icon on the left side of the posting menu.
Put your sketch between the code tags [code][/code]
i found this link pretty helpful to learn how to use timers (millis), for a newbie it takes a bit to get your head around, i downloaded the files for timer and opened the header and cpp files for timer. Atmel studio 7 is free and can open both files. i followed each line off code and wrote it down on paper, highlighting the functions and variables. once you can see step by step on paper, you will understand what timing is all about.
the biggest thing i learnt is
millis(); or micros(); both work the same way, every so often a behind the scenes counter overflows and updates the millis() and micros() counters.
unsigned long snapshot;
unsigned long (target);
void startTimer(){
1. unsigned long current;
2. current += (millis()-snapshot);
3. if(current >= target){
snapshot = millis();
timerUp = !timerUp;
variable current, (current millis)
this line stores millis - snapshot, snapshot is your (lastDebounceTime = millis()
if statement asks whether current millis has reached your target.
the code below uses classes, which is similar to a library but it is directly in your code.
when you use timers and your timer is finished the first thing you should do is take a snapshot. so you can refer to it on the next loop. from code below
if you run this code you can see how timers work, easier to learn timers first and then apply it to something like debouncing.
int pin13 = 13;
int pin9 = 9;
class TestTimer{
public:
bool timerUp;
void setTimer(unsigned long value){
target = value;
void startTimer(){
timerUp = !timerUp;
/*=========== Instantiate class members==============*/
TestTimer LED1;
TestTimer LED2;
void LED1Update(){
if (LED1.timerUp == false){
digitalWrite(pin13, LOW);
if(LED1.timerUp == true){
digitalWrite(pin13, HIGH);
void LED2Update(){
if (LED2.timerUp == false){
digitalWrite(pin9, LOW);
if(LED2.timerUp == true){
digitalWrite(pin9, HIGH);
//Serial.begin(115200);
pinMode(pin13, OUTPUT);
pinMode(pin9, OUTPUT);
LED1.setTimer(1000);
LED2.setTimer(10000);
LED1.startTimer();
LED2.startTimer();
LED1Update();
LED2Update();
/*========= loop time (25.7ms with 2 class members) ============*/
//static long x;
//static long last;
//x = ++x;
//if (x == 1000){
//serial.println(millis() - last);
//last = millis();
//x = 0;
/*========= loop time (73ms with 6 class members) ============*/
aarg,
not if you know where and what to look at, its easy for the old hands, but when your just starting up the examples can be a bit vague, even if you know what your looking for.
joeblogs:
aarg,
