Arduino Delay Timer Code to be Uploaded to ATTiny 45
Hello All,
I am a newbie at this and am working on my first real program. I have written an Arduino sketch that is doing what I want it to do and am going to upload to an ATTiny 45 using the TINY AVR programmer. I have pasted the code below.
Does anyone see any problems in the code that might cause a problem on the ATTiny 45 or some improvements to the code?
Thanks in advance,
Jeff
  This code reads JP1 and JP2 (Delay Select Jumpers) to determine the chosen tube warm-up delay
  according to the table below.
  JP1       JP2       DELAY(s)        DELAY(ms)
  HIGH      HIGH        75             75000
  LOW       HIGH        90             90000
  HIGH      LOW         105            105000
  LOW       LOW         120            120000
  Once the delay time is determined, the code waits for the appropriate number of milliseconds
  using the millis(s) function.  After the selected amount of time has elapsed, the the TXEnable
  pin is switched HIGH to alllow the amplifier to operate.
 //Define variables that do not change
const int DelaySelectPin1 = 4;
const int DelaySelectPin2 = 5;
const int TXEnablePin = 6;
//Define variables that do change
  int DelaySelectPin1Val = 0;
  int DelaySelectPin2Val = 0;
  unsigned long DelayVal = 0;
  unsigned long DelayTime = 0;
//Define pins and pin modes
  pinMode (DelaySelectPin1, INPUT_PULLUP);
  pinMode (DelaySelectPin2, INPUT_PULLUP);
  pinMode (TXEnablePin, OUTPUT);
//activate serial port for debugging
//Read the 2 delay select jumpers (JP1 and JP2) to determine what the delay value is in milliseconds
  DelaySelectPin1Val = digitalRead(DelaySelectPin1);
  DelaySelectPin2Val = digitalRead(DelaySelectPin2);
if (DelaySelectPin1Val == HIGH && DelaySelectPin2Val == HIGH) {
  DelayVal = 75000;
else if (DelaySelectPin1Val == LOW && DelaySelectPin2Val == HIGH) {
  DelayVal = 90000;
else if (DelaySelectPin1Val == HIGH && DelaySelectPin2Val == LOW) {
  DelayVal = 105000;
else {
   DelayVal = 120000;
//debugging section for verification of timer length
  Serial.print(DelaySelectPin1Val);
  Serial.println(DelaySelectPin2Val);
  delay(5000);
  Serial.println(DelayVal);
  Serial.println("START");
//Delay for the required number of millisecondshen and then enable the TXEnable pin
  Serial.println(currentMillis);
  if (currentMillis >= DelayVal) {
  DelayTime = DelayVal/1000;
  Serial.print(DelayTime);
  Serial.println(" second delay");
  digitalWrite(TXEnablePin,HIGH);
//Stop execution of the loop code and put the controller into endless loop until power-off and new power-on condition
while(1);
It may depend on the core you are using, but
  • ATtiny45 does not have pin 5 (in most cases)
  • ATtiny45 does not have pin 6
  • ATtiny45 does not have serial
so this code does not compile with the core I am using.
I think it can be done with ATtiny45 if you
  • change the pin numbers (0 to 4 are available)
  • omit all serial commands
Many thanks for the reply! Yes, I plan to remove all of the serial debugging code and change the pin numbers to the correct pins for the ATTiny45 when the time comes. Thanks for looking through it.
Jeff
