hi..I've interfaced a dht11 sensor with an arduino uno, & have plotted the the graph on serial plotter.......bt I don't know how to get number of peaks within a minute.I was thinking of adding the sensor values into an array, bt I don't know how to do that.....can anybody help? This is the code I've used
#include <dht.h>
#include "DHT.h"
#define dht_apin A0 // Analog Pin sensor is connected to
dht DHT;
void setup(){
delay(500);//Delay to let system boot
Serial.println("DHT11 Humidity & temperature Sensor\n\n");
delay(1000);//Wait before accessing Sensor
}//end "setup()"
void loop(){
//Start of Program
DHT.read11(dht_apin);
Serial.print("Current humidity = ");
Serial.print(DHT.humidity);
Serial.print("% ");
Serial.print("temperature = ");
Serial.print(DHT.temperature);
Serial.println("C ");
Serial.println(DHT.temperature); // Send the Signal value to Serial Plotter.
Serial.print("Find peak in the serial plotter");
delay(2000);//Wait 2 seconds before accessing sensor again.
//Fastest should be once every two seconds.
}// end loop()
