Can the Digital Pins on the Arduino Mega be a ground for example powering a motor thus allowing two pins polarity to be switched
Why don't I understand your question?
In theory yes. In practice no. There is a current limit per pin (20 mA safe maximum) and you need flyback diodes between plus-side and minus-side of the motor and with two possible plus-sides and two possible minus-sides that is not going to work as far as I see,
Yes - when they output a '0', that is ground.
Almost certainly not:
This is why motor drivers are used between an Arduino (or any other microcontroller) and a motor
Essentially yes provided the current is kept low. For example I drive a tiny stepper motor in a clock movement via a 220R series resistor from a pair of pins on a Nano to get bipolar current pulses.
No. Not directly for loads more than 20mA. You also run the risk of a power cross connect that can fry your card. What you want is an H-bridge motor driver card.
In principle it is possible but for very small motors and only enough to see that they work. Another question is how long everything will work this way.
