arduino dimmer
hi, the following code i m using....
const int ledPin = 12; // the pin that the LED is attached to
void setup() { // initialize the serial communication: Serial.begin(9600); // initialize the ledPin as an output: pinMode(ledPin, OUTPUT); }
void loop() { byte brightness;
// check if data has been sent from the computer: if (Serial.available()) { // read the most recent byte (which will be from 0 to 255): brightness = Serial.read(); // set the brightness of the LED: analogWrite(ledPin, brightness); } }
I have given the input such as 125, 225 , etc. from serial monitor but the LED on the pin 12 is always off(not responding). How can get it ?
Pin 12 is not a PWM pin.
k with a pwm pin its some what working but not going to OFF when i entered zero value, 0.
Where is the serial data coming from? If it is coming from the Serial Monitor, the value is coming in as a string, not a byte. So, 0 becomes '0', which is not the same.
serial data is coming from serial monitor
Then, you need to re-write your code to collect the whole string of characters, convert the string to a number, and use that value in the analogWrite call.
I'd suggest to try this:
ch = Serial.read();
// let's assume ch is a..z
ch -= 'a';
// map a..z letters to 0..100% pwm duty cycle
perc = map(ch, 0, 25, 0, 255);
analogWrite(pin, perc)
HTH
