Im sory for not answering on reply 17. I will post tomorow full program whitch is created in stepper.h library whitch workes fine , and what i succeeded to make in accelstepper library for now .
And yes i study and learnt some funkcion , how to start motor , move to anf somthing elshe but i eont know how to connect all together and put condition thet all of that works together .
Gm
This is stepeer.h code whitch work fine for me but i can use it , like you say
#include <Stepper.h>
const int stepsPerRevolution = 45; // 70% left
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
// set the speed at 40 rpm:
myStepper.setSpeed(40);
// initialize the serial port:
// step one revolution in one direction:(left)
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
delay(2000);//2 second pause
// step one revolution in the other direction:(right)
Serial.println("counterclockwise");
myStepper.step(-stepsPerRevolution);
soo i try transfer this code in AccelStepeer.h library
#include <AccelStepper.h>
AccelStepper myStepper(AccelStepper::FULL4WIRE, 8, 9, 10, 11);
myStepper.setMaxSpeed(40.0);
myStepper.move(stepsPerRevolution);
myStepper.move(-stepsPerRevolution);
delay(2000);
// --or absolute positioning
myStepper.moveTo(-stepsPerRevolution);
myStepper.runSpeedToPosition();
delay(2000);//2 second pause*/
code upload succes but nothing hepend with motor, motor freeze, can i do this on this way or i nitu use aproximtely miles to define position left and right, and how i can connect this code with (for loop) so i can count numper of repeated steps (19 time ) ? i hope i put all what you need to see where im stuck
tnx for reply
Please spend a few hours studying the AccelStepper library and trying some of its examples before trying to use it.
Then you will find that
myStepper.move();
has a very different meaning from its use in the simple Stepper library.
You need calls to .run() or .runSpeed() to make the motor move.
It is not reasonable to ask questions here that you could learn by studying the documentation for the library. I there is something in the documentation that you don't understand then I don't mind helping.
...R
Tnx for rply ,
None of them exmples dosen't work , motor only worm up and doing rly litle steps. Mybe is problem because i try to control this with l298 driver ?
marinac94:
Then post the exact code that you uploaded for one of the examples that doesn't work and post a photo of a simple drawing showing how you have everything connected.
I don't think you have told us exactly what stepper motors you are using so post a link to the motor datasheet.
And tell us what motor power supply you are using (volts and amps).
...R
Hello , this is sketch of conection. Imgur: The magic of the Internet , i have computer power whitch is revised to kolektoe for 12 V (16A) ,5V (20A) 3.3V (14A) , step motor - Mitsumi M42SP-6TG and i obly found this motor have 10 ohm , nothing else... I found it in computer printer .. connection - 5V and GND to arduino , 12 Vand GND to l298 shild , step motor wires to A+A-B+B- , in1,in2,in3,in4- 8,9,10,11 pins on arduino , program whitch i wana rune is this ...
#include <AccelStepper.h> AccelStepper stepper( AccelStepper::FULL4WIRE, 8, 9, 10, 11);
stepper.setMaxSpeed(150);
stepper.setAcceleration(100);
stepper.moveTo(500);
while (stepper.currentPosition() != 300) // Full speed up to 300
stepper.run();
stepper.stop(); // Stop as fast as possible: sets new target
stepper.runToPosition();
// Now stopped after quickstop
// Now go backwards
stepper.moveTo(-500);
while (stepper.currentPosition() != 0) // Full speed basck to 0
stepper.run();
. Tnx for rply
The program you posted is wrong. What you have on the first line should be on two lines.
Does it work when you correct that?
And why not start with the much simpler ConstantSpeed example?
If your program still does not work please post a diagram showing all the connections (as I requested in Reply #24). It is too easy to misunderstand verbal wiring descriptions.
...R
I know this need to be in 2 row , bad coping with mobile phone sry for that , const spped examp rune fine . Problem with program whitch i post before is same direction full time , after quick stop motor will need go back to 0 , be he rune in same direction
marinac94:
Then please take the trouble to use your PC so that I am not commenting on irrelevant problems. It should also mean that you avoid silly spelling mistakes.
Can you make the motor move in both directions by modifying that simple example?
...R
yes i can this code will work fine , rune to position, and back or ? my motor only vibrating in same place
int motor = 150;
AccelStepper stepper(AccelStepper::FULL4WIRE, 8, 9, 10, 11);
stepper.setMaxSpeed(200);
stepper.setSpeed(100);
stepper.moveTo(motor);
stepper.runSpeedToPosition();
if (stepper.distanceToGo() == 0 )
stepper.moveTo(-stepper.currentPosition());
marinac94:
It's a very strange way to do the two directions but I can see how it would work.
What I can't understand is why you say "this code will work fine , rune to position, and back" and then in the same sentence say "or ? my motor only vibrating in same place"
Does it work fine? or does it not work fine?
Try this
int motor = 150;
and if that is better think hard about what is different about it and why the change has helped.
...R
What i said in last post i ment that code witch i send should work fine as much as I could see in Accelstepper library, but it doesn't work . I'm sorry for misunderstanding. I'll check your code later. Thanks
marinac94:
Then make things even simpler. Just stay with the simple AccelStepper ConstantSpeed example until that works properly.
Try it, and tell me exactly what happens.
...R
hello, I'm testing your code and it does not work, motor only frezzes, it dose not move
finally i succeeded :DD
this code do what i rly need, move to position pause 2 second, and return to 0, how can i set limit of repetition, i need 19 repetition. Can i just write 19 time same code ori can use somthing like this (i=1; i<=19; i++)
tnx you for all help, Everything is in learning and researching ![]()
// Change these to suit your stepper if you want
stepper.setMaxSpeed(100);
stepper.setAcceleration(50);
stepper.setSpeed(50);
stepper.moveTo(40);
delay(2000);
while (stepper.distanceToGo() != 0)
{ stepper.run();
stepper.moveTo(0);
delay(2000);// set target back at start position
{ stepper.run();
stepper.moveTo(40);
delay(2000);
{ stepper.run();
marinac94:
finally i succeeded :DDthis code do what i rly need, move to position pause 2 second, and return to 0, how can i set limit of repetition,
Glad to hear you are making progress.
Before you go any further you now need to learn how to use the AccelStepper library properly - with the code in loop() rather than in setup().
Get the ConstantSpeed example to work and report back.
...R
