Arduino DMX Examples not working?
I’m trying to power 4 DMX channels with an Arduino diecimila. I keep getting an error in my code saying:
error: port_to_output is not declared in this scope
This is the example code from the Arduino website:
/* DMX Shift Out for arduino - 004 and 005
 * Shifts data in DMX format out to DMX enabled devices
 * it is extremely restrictive in terms of timing. Therefore
 * the program will stop the interrupts when sending data
 * The elektronic foundation for DMX is RS 485, so you have to use
 * a MAX-485 or a 75176.
 * wirring for sending dmx with a MAX-485
    1 - RO  - Receiver Output --- set to ground with a 100 ohm resistor
    2 - RE  - Receiver Output Enable -- set to ground
    3 - DE  - Driver Output Enable -- set to 5v
    4 - DI  - Driver Input -- Input from Arduino
    5 - GnD - Ground Connection -- set to ground -- refence for the DMX singal --- (DMX pin 1)
    6 - A   - Driver Output / Receiver Input -- DMX Signal (hot)------------------ (DMX pin 3)
    7 - B   - Driver Output / Receiver Input -- DMX Signal inversion ( cold)------ (DMX pin 2)
    8 - Vcc - Positive Supply -- 4,75V < Vcc < 5,25V
 * Every dmx packet contains 512 bytes of information (for 512 channels).
 * The start of each packet is market by a start byte (shiftDmxOut(sig,0);),
 * you should always send all 512 bytes even if you don*t use all 512 channels.
 * The time between every dmx packet is market by a break
 * between 88us and 1s ( digitalWrite(sig, LOW); delay(10);)
 * (cleft) 2006 by Tomek Ness and D. Cuartielles
 * K3 - School of Arts and Communication
 * fhp - University of Applied Sciences
 * <http://www.arduino.cc>
 * <http://www.mah.se/k3>
 * <http://www.design.fh-potsdam.de>
 * @date: 2006-09-30
 * @idea: Tomek Ness
 * @code: D. Cuartielles and Tomek Ness
 * @acknowledgements: Johny Lowgren for his DMX devices
int sig = 11;
int count = 0;
int swing = 0;
int updown = 0;
/* Sends a DMX byte out on a pin.  Assumes a 16 MHz clock.
 * Disables interrupts, which will disrupt the millis() function if used
 * too frequently. */
void shiftDmxOut(int pin, int theByte)
    int wasteTime = 0;
    int theDelay = 1;
    int count = 0;
    int portNumber = port_to_output[digital_pin_to_port[pin].port];
    int pinNumber = digital_pin_to_port[pin].bit;
    // the first thing we do is to write te pin to high
    // it will be the mark between bytes. It may be also
    // high from before
        _SFR_BYTE(_SFR_IO8(portNumber)) |= _BV(pinNumber);
    delayMicroseconds(10);
    // disable interrupts, otherwise the timer 0 overflow interrupt that
    // tracks milliseconds will make us delay longer than we want.
    cli();
        // DMX starts with a start-bit that must always be zero
        _SFR_BYTE(_SFR_IO8(portNumber)) &= ~_BV(pinNumber);
        //we need a delay of 4us (then one bit is transfert)
        // at the arduino just the delay for 1us is precise every thing between 2 and 12 is jsut luke
        // to get excatly 4us we have do delay 1us 4 times
        delayMicroseconds(theDelay);
         for (count = 0; count < 8; count++) {
                if (theByte & 01) {
            else {
              // to write every bit exactly 4 microseconds, we have to waste some time here.
              //thats why we are doing a for loop with nothing to do, a delayMicroseonds is not smal enough
              for (wasteTime =0; wasteTime <2; wasteTime++) {}
                theByte>>=1;
    // the last thing we do is to write the pin to high
    // it will be the mark between bytes. (this break is have to be between 8 us and 1 sec)
    // reenable interrupts.
    sei();
  pinMode(sig, OUTPUT);
  digitalWrite(13, HIGH);
void loop()  {
   // sending the break (the break can be between 88us and 1sec)
   delay(10);
   //sending the start byte
   shiftDmxOut(sig,0);
   shiftDmxOut(sig, 255); //1
   shiftDmxOut(sig, 0); //2
   shiftDmxOut(sig, 0); //3
   shiftDmxOut(sig, 0); //4
   shiftDmxOut(sig, 0); //5
   shiftDmxOut(sig, 0); //6
   shiftDmxOut(sig, 0); //7
   shiftDmxOut(sig, 255); //8
   for (count = 1; count<=504; count++){  //the rest
Now I’ve modified the code in order to function properly. Per the directions given in this topic:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1205193597/0#9
The modified code will come in the next post!
This is my modified code.
 * @date: 2006-09-30
 * @idea: Tomek Ness
int sig = 3;
#define ledPin 13
int count = 0;
int swing = 0;
int updown = 0;
#include "pins_arduino.h";
int port_to_output[] = {
  NOT_A_PORT,
  NOT_A_PORT,
  _SFR_IO_ADDR(PORTB),
  _SFR_IO_ADDR(PORTC),
  _SFR_IO_ADDR(PORTD)
  int value = 0;
int valueadd = 3;
    NOT_A_PORT,
    NOT_A_PORT,
    _SFR_IO_ADDR(PORTD)
    int wasteTime = 0;
  int theDelay = 1;
  int count = 0;
  int portNumber = port_to_output[digitalPinToPort(pin)];
  int pinMask = digitalPinToBitMask(pin);
  int pinNumber = digitalPinToBitMask(pin);
  // high from before
  cli();
  // we need a delay of 4us (then one bit is transferred)
  // this seems more stable then using delayMicroseconds
  asm("nop\n nop\n nop\n nop\n nop\n nop\n nop\n nop\n");
    if (theByte & 01) {
    else {
    //for (wasteTime =0; wasteTime <2; wasteTime++) {}
    theByte>>=1;
  sei();
  Serial.begin(300);        // initialize serial communications
  digitalWrite(sig, HIGH);
void loop()  {
  int i;
  for(i=1;i<=4;i++){            // LED boot sequence -- blinks 4 times
    digitalWrite(ledPin, HIGH);
    delay(50);
    digitalWrite(ledPin, LOW);
    delay(50);
  while(1){
    /***** sending the dmx signal *****/
    delay(10);
    if (Serial.available() > 0) {
      int value1 = Serial.read();
      // sending the start byte
      shiftDmxOut(sig, value1); //1
      shiftDmxOut(sig, value1); //2
      shiftDmxOut(sig, value1); //3
      shiftDmxOut(sig, value1); //4
      for (count = 1; count<=508; count++){  //the rest
        shiftDmxOut(sig, value2);
My dimmer does not recognise this as a DMX signal. However the example in the forum-post did work for me, it did not work with multiple channels.
Does anyone know what I’m missing here? Thanks in advance!
OK the last code does work, however I had a previousm mod to my arduino causing a short.
