I am looking to use the EthernetDNS library to look up a specific server every time and get its IP without any user interaction. the current code that requires me to type in the hostname into the serial monitor is as follows. I tried just defining the hostname as my address but that didn't work.
// Copyright (C) 2010 Georg Kaindl
// http://gkaindl.com
// This file is part of Arduino EthernetDNS.
// EthernetDNS is free software: you can redistribute it and/or modify
// it under the terms of the GNU Lesser General Public License as
// published by the Free Software Foundation, either version 3 of
// the License, or (at your option) any later version.
// EthernetDNS is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with EthernetDNS. If not, see
// <http://www.gnu.org/licenses/>.
// Illustrates how to do non-blocking DNS queries via polling.
#if defined(ARDUINO) && ARDUINO > 18
#include <SPI.h>
#endif
#include <Ethernet.h>
#include <EthernetDNS.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// substitute an address on your own network here
byte ip[] = { 192, 168, 0, 250 };
// substitute your DNS server ip address
byte dnsServerIp[] = { 192, 168, 0, 1};
// NOTE: Alternatively, you can use the EthernetDHCP library to configure your
// Ethernet shield and find out the DNS server IP address.
const char* ip_to_str(const uint8_t*);
Ethernet.begin(mac, ip);
Serial.println("Enter a host name via the Arduino Serial Monitor to have it "
"resolved.");
// You will often want to set your own DNS server IP address (that is
// reachable from your Arduino board) before doing any DNS queries. Per
// default, the DNS server IP is set to one of Google's public DNS servers.
EthernetDNS.setDNSServer(dnsServerIp);
char hostName[512];
int length = 0;
while (Serial.available()) {
hostName[length] = Serial.read();
length = (length+1) % 512;
delay(50);
hostName[length] = '\0';
if (length > 0) {
byte ipAddr[4];
Serial.print("Resolving ");
Serial.print(hostName);
Serial.print("...");
// Let's send our DNS query. If anything other than DNSSuccess is returned,
// an error has occurred. A full list of possible return values is
// available in EthernetDNS.h
DNSError err = EthernetDNS.sendDNSQuery(hostName);
if (DNSSuccess == err) {
do {
// This will not wait for a reply, but return immediately if no reply
// is available yet. In this case, the return value is DNSTryLater.
// We can use this behavior to go on with our sketch while the DNS
// server and network are busy finishing our request, rather than
// being blocked and waiting.
err = EthernetDNS.pollDNSReply(ipAddr);
if (DNSTryLater == err) {
// You could do real stuff here, or go on with a your loop(). I'm
// just printing some dots to signal that the query is being
// processed.
delay(20);
Serial.print(".");
} while (DNSTryLater == err);
// Finally, we have a result. We're just handling the most common errors
// here (success, timed out, not found) and just print others as an
// integer. A full listing of possible errors codes is available in
// EthernetDNS.h
Serial.print("The IP address is ");
Serial.print(ip_to_str(ipAddr));
Serial.println(".");
} else if (DNSTimedOut == err) {
Serial.println("Timed out.");
} else if (DNSNotFound == err) {
Serial.println("Does not exist.");
Serial.print("Failed with error code ");
Serial.print((int)err, DEC);
// Just a utility function to nicely format an IP address.
const char* ip_to_str(const uint8_t* ipAddr)
static char buf[16];
sprintf(buf, "%d.%d.%d.%d\0", ipAddr[0], ipAddr[1], ipAddr[2], ipAddr[3]);
return buf;
