Arduino DO sensor via Arduino Mega 2560 & ladyAda Datalogger
Hello,
I need help adjusting the code so that I can
A) map 1023 to 0-255 scale
B) multiply the results of all the potentiometers by 0.68966
C) Record and Display in the serial monitor and datalog file on the datalogger
here it is: /*
SD card datalogger
The circuit:
  • analog sensors on analog ins 0, 1, and 2
  • SD card attached to SPI bus as follows:
    ** MOSI - pin 11
    ** MISO - pin 12
    ** CLK - pin 13
    ** CS - pin 4
#include <SD.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 10;
analogReference(INTERNAL1V1);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(53, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += ",";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
Thank you
Otherwise known as divide by 4.
There is a handy * operator.
That code already does that (poorly). What help do you need?
how do I use the * operator with a string?
vmogli:
A = 3*4 //This results with A=12
You may want to take some time and do a C tutorial. It will help you immensely when trying to code in C.
Thank you
