Arduino does not receive data from PHP until I run tests with the serial monitor
Hi, how are you,
Thank you for reading my query, which I will tell you below:
I have been working on sending data through my serial port from PHP to Arduino UNO, but it happens that when testing from the php form nothing happens, then I open the serial monitor and everything works fine, I close the serial monitor and I return to the php application and it works correctly. When reloading the program in arduino the same thing happens, it does not work until you run a test on the serial monitor, otherwise the php application DOES NOT WORK. Working on Windows 8.1 platform (64 bit), Netbeans 8.2, Xampp 7.1.1 (Apache), and Arduino IDE 1.8.1
PHP/HTML source:
<?php 'mode COM4: BAUD=9600 PARITY=N data=8 stop=1 xon=off'; $fp = fopen ("COM4:", "w+"); if (!$fp) { echo "Error al abrir COM 4."; } else { $datos= escapeshellcmd($_REQUEST["numero"]); fputs ($fp, $datos ); fclose ($fp); } ?> Par o impar
enciende led
Ingresar un n° 3 para encender LED.
Escribe un número:
Arduino source:
int ledPin = 13;
int input = 0;
pinMode(ledPin, OUTPUT);
Serial.write(“conectado”);
if (Serial.available() > 0) {
input = Serial.read();
if (input > 0) {
if (input == ‘3’){
digitalWrite(ledPin, HIGH);
else {
digitalWrite(ledPin, LOW);
input = 0;
thanks you…!
Your php script does not maintain the serial connection open, when the script has finished running the port is probably closed.
Also with a uno, opening the serial console to the arduino port will reset the arduino, may be would be good to wait a bit before sending something on that serial, the uno might not be ready yet
puede ser por falta de alguna librería?
todosucedeporalgo: puede ser por falta de alguna librería?
Say what?
