Hi everyone!
so I have an issue with my Arduino.
i am making an automatic chicken coop door. The code seems to 'sometimes' ( without changing anything it sometimes doesn't or does) run when I connect it to my laptop, however. when I eject the usb it stops functioning. It does do a little bit of the first proces, but then stops and ignores every command.
I hope someone can help me.
I attached the wiring diagram and the code.
Thanks in advance !
//Chicken coop door
int DoorGoodmorning = 550; // lightvalue when door must go open
int DoorGoodnight = 450; // lightvalue when door must close
int DoorPulses = 35; // amount of pulses needed to close the door ( travel 35cm)
const int DoorMeasurements = 5; // Average of the amount of measurements to decide
const int intervalvalue = 60; // amount of seconds to pause between measurements
const int motortin1Pin = 5;
const int motortin2Pin = 4;
const int magnetPin = A1;
const int ldrPin = A2; // LDR
const int GreenLed = 9;
const int RedLed = 8;
// variables
int intervalcounter = 0;
int doorStatus = 1; // doorStatus, 1=open, 0=closed
int intMeasureMoment = 0; // position in arrey of lightmeasurements
uint16_t light[DoorMeasurements]; // array with the lightmeasurements
void setup(void) {
Serial.begin(57600);
Serial.println("ChickenDoor");
pinMode(motortin1Pin, OUTPUT);
pinMode(motortin2Pin, OUTPUT);
pinMode(GreenLed, OUTPUT); // The Green LED turns on when the door is closed
pinMode(RedLed, OUTPUT); // Red LED turns on when the door is in opening or closing sequence
pinMode(ldrPin, INPUT); //ldr+plus en ldr+port+10k
pinMode(magnetPin, INPUT_PULLUP); //between 0 and the pin
// filling measurement array with default average
for (int counter = 0; counter < DoorMeasurements; counter++) {
light[counter] = (DoorGoodmorning + DoorGoodnight) / 2;
// setting variables
doorStatus = 0;
// at start the door closes a lttle and then re-opens to sync the motor and check if LED's work
TestDoor();
void TestDoor(void) {
digitalWrite(motortin1Pin, LOW);
digitalWrite(motortin2Pin, HIGH);
digitalWrite(GreenLed, HIGH);
digitalWrite(RedLed, HIGH);
for (int counter = 0; counter < 5; counter++) delay(1000);
OpenDoor();
void CloseDoor(void) {
for (int counter = 0; counter < DoorPulses; counter++) delay(1000);
// motor uit
digitalWrite(motortin2Pin, LOW);
digitalWrite(RedLed, LOW);
void OpenDoor(void) {
digitalWrite(GreenLed, LOW);
while (digitalRead(magnetPin) == 0) { //when value = 0, the door is not (fully) open
digitalWrite(motortin1Pin, HIGH);
// motor off
void ProcesDoor(void) {
uint16_t average = 0;
//retrieve lightmeasurements
light[intMeasureMoment] = analogRead(ldrPin); // put measured value in array
intMeasureMoment++; // rise array position
if (intMeasureMoment >= DoorMeasurements) intMeasureMoment = 0; // if array is filled, start at beginning with filling
// calculate average of the array
average = 0;
average += light[counter];
average = average / DoorMeasurements;
// decide if door should open or close
if ((average <= DoorGoodnight) && (digitalRead(magnetPin) == 1)) { // door must be open, if it is going to close
CloseDoor();
doorStatus = 1;
if (average >= DoorGoodmorning) {
OpenDoor();
doorStatus = 0;
void loop(void) {
//taskcompletion. must be every minute
while (intervalcounter < intervalvalue) {
intervalcounter++;
Serial.print("LDR Value: ");
Serial.print(analogRead(ldrPin));
Serial.print(" Door Status: ");
Serial.print(doorStatus);
Serial.print(" Magnet switch: ");
Serial.println(digitalRead(magnetPin));
ProcesDoor();
Documentscans 13.pdf (198 KB)
