Arduino doesn't respond to serial input from MATLAB
Hello all,
I was working on a project wherin it is required to send inputs from matlab to Arduino serially through usb. The Arduino accepts the data but it is not responding.
I have tried changing the baud rates but doesn’t help. But when i give inputs from serial monitor the Arduino responds perfectly. Please help
Please post your Arduino and MATLAB code. We can't be much help without that.
What exactly is your project supposed to do (as detailed as possible).
here is the code sir
please do help
sketch_may21a.ino (2.99 KB)
MY project is about reading brain signals through eeg headdset into matlab. And send alphabets A B C D from matlab to arduino through serial port based on the value of the brain signals.
the problem is the data is sent from matlab to arduino but arduino doesnt operate as per the program.
when giving input through matlab command window it does the desired operation.
matlab Code
TG_DATA_ATTENTION = 2;
%$Matlab code to read attention using Mindwave mobile
%Clear Screen
clc;
%Clear Variables
clear all;
%Close figures
close all;
%Preallocate buffer
data_att = zeros(1,256);
%Comport Selection
portnum1 = 14;
%COM Port #
s = serial('COM10','Baudrate',9600);
comPortName1 = sprintf('\\\\.\\COM%d', portnum1);
% Baud rate for use with TG_Connect() and TG_SetBaudrate().
TG_BAUD_115200 = 9600;
% Data format for use with TG_Connect() and TG_SetDataFormat().
TG_STREAM_PACKETS = 0;
% Data type that can be requested from TG_GetValue().
%load thinkgear dll
loadlibrary('Thinkgear.dll');
%To display in Command Window
fprintf('Thinkgear.dll loaded\n');
%get dll version
dllVersion = calllib('Thinkgear', 'TG_GetDriverVersion');
%To display in command window
fprintf('ThinkGear DLL version: %d\n', dllVersion );
% Get a connection ID handle to ThinkGear
connectionId1 = calllib('Thinkgear', 'TG_GetNewConnectionId');
if ( connectionId1 < 0 )
error( sprintf( 'ERROR: TG_GetNewConnectionId() returned %d.\n', connectionId1 ) );
end;
% Attempt to connect the connection ID handle to serial port "COM3"
errCode = calllib('Thinkgear', 'TG_Connect', connectionId1,comPortName1,TG_BAUD_115200,TG_STREAM_PACKETS );
if ( errCode < 0 )
error( sprintf( 'ERROR: TG_Connect() returned %d.\n', errCode ) );
end
fprintf( 'Connected. Reading Packets...\n' );
i=0;
j=0;
disp('Reading Brainwaves');
figure;
while 1
if (calllib('Thinkgear','TG_ReadPackets',connectionId1,1) == 1) %if a packet was read...
if (calllib('Thinkgear','TG_GetValueStatus',connectionId1,TG_DATA_ATTENTION ) ~= 0)
j = j + 1;
i = i + 1;
%Read attention Valus from thinkgear packets
data_att(j) = calllib('Thinkgear','TG_GetValue',connectionId1,TG_DATA_ATTENTION );
disp(data_att(j));
fopen(s);
if(data_att(j)>5 && data_att(j)<35)
% disp('Forward');
% fopen(s);
        fprintf(s,'%s','A');
        %fprintf(s,'A');
        % pause(1);
       %  resume();
%         fclose(s);
end
if(data_att(j)>35 && data_att(j)<65)
% disp('right');
% fopen(s);
        fprintf(s,'%s','B');
       % fprintf(s,'B');
        %pause(1);
      %  resume();
%         fclose(s);
end
if(data_att(j)>65 && data_att(j)<95)
%disp('left');
% fopen(s);
        fprintf(s,'%s','C');
         %pause(1);
       %  resume();
      %  fclose(s);
end
if(data_att(j)==0)
%disp('robot arm');
% tic;
%while toc < 10
 %   end
% fopen(s);
        fprintf(s,'%s','D');
         %pause(1);
     %    resume();
%        fclose(s);
end
%Plot Graph
fclose(s);
plot(data_att);
title('Attention');
%Delay to display graph
%pause(1);
end
end
end
disp('Loop Completed')
%Release the comm port
calllib('Thinkgear', 'TG_FreeConnection', connectionId1 );
Matlab is expensive. Most people won’t have it on their computers to help you debug.
You will have to learn how to use your brain and troubleshoot this.
I have been trying to troubleshoot this but in vain.
I thought there might be someone who'll help me out
May be you will luck out. I don't have Matlab.
If you don't learn now how to think through a problem and learn to solve it, later while on the job won't be a good time.
ok sir
yeshas436:
please do help
You have no code in the Arduino program to let you see what it is actually receiving.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
...R
