Hello,
posting after a long time so apologies for any mistake.
here is a code of my project which is about a personal gps tracker. But its in testing phase now, so i am using a led to mimic a task which has to be done after parsing SMS from SIM800L module. The problem is after only the "led on" command works but "led off" doesn't. I am unable to figure out if there is an error in my test code or something else.
#include <SoftwareSerial.h>
#include <Keypad.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
SoftwareSerial sim800(3, 2); //SIM800L Tx & Rx is connected to Arduino #3 & #2
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32(Original) and for some 128x64 chinese clones
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO, NANO, PRO MINI: A4(SDA), A5(SCL)
#define LED_PIN 13
#define BUFFER_SIZE 64 // incoming data buffer size
char bufferData[BUFFER_SIZE]; // holds the char data
char bufferIndex; // holds the position of the char in the buffer
char sender_cmd[10]; // holds the specific command when a new SMS is received
String sender_num = "xxxxxxxxxxx";
bool CMD_OK = false; // CMD is for processing the parsing the sms command
int cmd_pos_index = 0;
int cmd_pos_count = 0;
float gpslat, gpslon;
boolean livetrack_status = false;
boolean alarm_status = false;
boolean led_status = false;
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// 'gps', 128x64px
const unsigned char hypertraklogo [] PROGMEM = {
sim800.begin(9600);//start gsm serial communication
Serial.println("Initializing...");
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, led_status);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS);
display.clearDisplay();//Prevents Adafruit splash screen
display.drawBitmap(0, 0, hypertraklogo, 128, 64, WHITE);//This function draws custom logo
display.display();
delay(7000);//wait 5-10 secs for gsm to register to a network
// Clear the buffer
initializeGSM();
memset(bufferData, 0, sizeof(bufferData)); // Initialize the string
bufferIndex = 0;
Serial.println("Setup done");
manageGSM();
void initializeGSM() // Set to receive mode
sim800.println("AT\r"); //Once the handshake test is successful, it will back to OK
updateSerial();
sim800.println("AT+CMGF=1\r");//Configuring SMS as TEXT mode
updateSerial();
sim800.println("AT+CNMI=1,2,0,0,0\r");// Decides how newly arrived SMS messages should be handled
updateSerial();
sim800.println("AT&W");
updateSerial();
void manageGSM()
while (sim800.available() > 0)
bufferData[bufferIndex] = sim800.read();
// Find the string "CMD:"
// if found, parse the command for processing
if ( (bufferData[bufferIndex - 3] == 'C') &&
(bufferData[bufferIndex - 2] == 'M') &&
(bufferData[bufferIndex - 1] == 'D') &&
(bufferData[bufferIndex] == ':') )
//Serial.println("CMD");
CMD_OK = true;
memset(sender_cmd, 0, sizeof(sender_cmd));
cmd_pos_index = bufferIndex; // get the position
cmd_pos_count = 0; // reset pos counter
if ( ( (bufferIndex - cmd_pos_index) > 1 ) && (CMD_OK))
if (bufferData[bufferIndex] == '<')
//Serial.println(sender_cmd);
processCommand();
CMD_OK = false; // done
sender_cmd[cmd_pos_count] = bufferData[bufferIndex];
cmd_pos_count++;
bufferIndex++;
bufferIndex = 0;
void processCommand()
if (strcmp(sender_cmd, "Led on") == 0)
led_status = true;
sendSMS("LED On", sender_num);
else if (strcmp(sender_cmd, "Led off") == 0)
led_status = false;
sendSMS("LED Off", sender_num);
void sendSMS(String message, String mobile)
sim800.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
sim800.println("AT+CMGS=\"" + mobile + "\"\r"); //Mobile phone number to send message
updateSerial();
sim800.println(message); // This is the message to be sent.
updateSerial();
sim800.println((char)26); // ASCII code of CTRL+Z to finalized the sending of sms
updateSerial();
void updateSerial()
while (Serial.available())
sim800.write(Serial.read());//Forward what Serial received to Software Serial Port
while (sim800.available())
Serial.write(sim800.read());//Forward what Software Serial received to Serial Port
Here is the code. P.S- i have removed the custom logo code from here as it was exceeding 9000 characters limit.
Any help is appreciated
