Hello everyone,
I am running into an issue with Arduino i have not ran into yet. Everything has been running smoothly until i added a new function called send_all_angles() that calls two other functions in its class. It does not reach this function in the program before the effect is seen. After seeing this i commented out the two function calls in send_all_angles() and it worked fine again. After that i uncommented the first function, it worked, and anytime i comment out the second function the error occurs. Compiler has no warnings and the function call that causes the error in send_all_angles() is tested and working in other functions.
This is running on an Arduino UNO and is operating a Braccio Robot Arm. When the code in uncommented the robot arm becomes unresponsive (it does not even go into its default position). This is all before send_all_angles() is called.
The error is it either resets over and over or sends garbage on the serial.
With the function create_send_msg() in send_all_angles() commented out (which is the line that causes the error) the compiler says
Sketch uses 8330 bytes (25%) of program storage space. Maximum is 32256 bytes.
Global variables use 797 bytes (38%) of dynamic memory, leaving 1251 bytes for local variables. Maximum is 2048 bytes.
With the function put into the program the compiler says
Sketch uses 8608 bytes (26%) of program storage space. Maximum is 32256 bytes.
Global variables use 831 bytes (40%) of dynamic memory, leaving 1217 bytes for local variables. Maximum is 2048 bytes.
send_all_angles() can be found on line 82 of braccio_arm.cpp and is the 4th or 5th function down.
braccio_arm.h below
#ifndef _BRACCIO_ARM_H
#define _BRACCIO_ARM_H
#include <Arduino.h>
#include <stdint.h>
#include <errno.h>
#include "braccio.h"
#include <Servo.h>
#define DFLT_STEP_DELAY 20 // ms
#define MSG_SIZE_NO_PARAM 4 // msg_len, msg_type, cmd, param_len, 4 bytes
#define PARAM_BUFF 250
#define IO_MSG_BUFF (MSG_SIZE_NO_PARAM + PARAM_BUFF)
#define PARAM_STRLEN 0
// msg type definitions
#define CMD_MSG 0x0
#define PRINT_MSG 0x1
#define ACK 0x2
#define FINISH 0x3
// outgoing cmd definitions
#define PRINT_GENERAL 0x0
#define PRINT_ERROR 0x1
#define PRINT_VERBOSE 0x2
#define SEND_ANGLES 0x3
// incomming cammands
enum servo_angle_cmd {
M1_ANGLE=1, // base 1
M2_ANGLE, // shoulder 2
M3_ANGLE, // elbow 3
M4_ANGLE, // wrist vertial 4
M5_ANGLE, // wrist rotation 5
M6_ANGLE, // gripper 6
MX_ANGLE, // braccio_arm for all servo angles at once 7
REQUEST_MX_ANGLE // requesting all angles to be sent 8
// min max angles
#define M1_MIN_ANGLE 0
#define M1_MAX_ANGLE 180
#define M2_MIN_ANGLE 15
#define M2_MAX_ANGLE 165
#define M3_MIN_ANGLE 0
#define M3_MAX_ANGLE 180
#define M4_MIN_ANGLE 0
#define M4_MAX_ANGLE 180
#define M5_MIN_ANGLE 0
#define M5_MAX_ANGLE 180
#define M6_MIN_ANGLE 10 // tongue is open
#define M6_MAX_ANGLE 73 // gripper is closed
// Safety angles
// NOTE: This may differ from the getting started guide. the getting started
// guide does not match the Braccio.begin() code. These angles are the
// default position as given in the Braccio.h library with some
// modification. Note the init does not set everything the same as this
// for some reason. Notes in the braccio library.
#define M1_SAFE_ANGLE 0
#define M2_SAFE_ANGLE 40
#define M3_SAFE_ANGLE 180
#define M4_SAFE_ANGLE 170
#define M5_SAFE_ANGLE 90
#define M6_SAFE_ANGLE 73
typedef struct parsed_io_msg {
uint8_t msg_size;
uint8_t msg_type;
uint8_t cmd;
uint8_t param[PARAM_BUFF];
uint8_t param_len;
} parsed_msg_s;
typedef struct io_msg {
uint8_t msg[IO_MSG_BUFF];
uint8_t len;
} io_msg_s;
#define NUM_ANGLES 6 // m[1-6]
typedef struct braccio_angles {
uint8_t m1;
uint8_t m2;
uint8_t m3;
uint8_t m4;
uint8_t m5;
uint8_t m6;
} braccio_angles_s;
class braccio_arm {
public:
braccio_arm(Stream &serial);
~braccio_arm();
void init_arm(int soft_start_level=SOFT_START_DEFAULT);
void set_default_pos();
bool serial_avail();
int serial_read(uint8_t *buff, size_t len);
int set_parsed_msg(parsed_msg_s *fill, uint8_t msg_type, uint8_t cmd,
uint8_t param_len, uint8_t *param);
int parse_msg(uint8_t *msg, parsed_msg_s *in_msg);
int exec_command(parsed_msg_s *in_msg);
void send_ack();
void send_finish();
int send_print(const char *format, ...);
int send_verbose(const char *format, ...);
int send_error(const char *format, ...);
int send_all_angles();
int create_send_msg(parsed_msg_s *msg);
int create_io_msg(parsed_msg_s *msg, io_msg_s *io_msg);
int send_message(io_msg_s *msg);
private:
uint8_t check_angle(uint8_t angle, uint8_t min, uint8_t max);
void check_all_angles(uint8_t a1, uint8_t a2, uint8_t a3, uint8_t a4,
uint8_t a5, uint8_t a6);
int vsnprintf_check(char *buff, int size, const char *format,
va_list args);
Stream &serial;
braccio_angles_s angles;
* NOTE: There is a _Braccio class object declared as extern globably in
* Braccio.h named Braccio. We must declare our servos globally
* in the .cpp file for externs in Braccio.cpp.
* I commented out the global braccio class extern in the llibrary
* header and declared my own variable here.
* If you downloaded Braccio.h via arduino IDE it is usually
* in ~/Arduino/libraries/
* You do not need to comment it out for this to work but it may
* take up space.
_Braccio braccio;
#endif
braccio_arm.cpp
#include "braccio_arm.h"
#define SUCCESS 0
#define FAILURE -1
// these must be declared for extern variables in the Braccio library
// in Braccio.cpp
Servo base;
Servo shoulder;
Servo elbow;
Servo wrist_ver;
Servo wrist_rot;
Servo gripper;
braccio_arm::braccio_arm(Stream &serial): serial(serial)
// set default angles into saftey position
angles.m1 = M1_SAFE_ANGLE;
angles.m2 = M2_SAFE_ANGLE;
angles.m3 = M3_SAFE_ANGLE;
angles.m4 = M4_SAFE_ANGLE;
angles.m5 = M5_SAFE_ANGLE;
angles.m6 = M6_SAFE_ANGLE;
braccio_arm::~braccio_arm()
// initialize robot arm to default position and sets variables in braccio
void braccio_arm::init_arm(int soft_start_level)
send_verbose("Starting Braccio\n");
braccio.begin(soft_start_level);
set_default_pos();
void braccio_arm::set_default_pos()
send_verbose("setting default position\n");
braccio.ServoMovement(DFLT_STEP_DELAY, angles.m1, angles.m2, angles.m3,
angles.m4, angles.m5, angles.m6);
send_verbose("default position set\n");
bool braccio_arm::serial_avail()
if (serial.available())
return true;
return false;
int braccio_arm::serial_read(uint8_t *buff, size_t len)
int num_recv;
num_recv = serial.readBytes(buff, len); // room for '\0'
return num_recv;
int braccio_arm::send_all_angles()
parsed_msg_s out_msg;
uint8_t param[NUM_ANGLES] = {angles.m1, angles.m2, angles.m3, angles.m4,
angles.m5, angles.m6};
set_parsed_msg(&out_msg, CMD_MSG, SEND_ANGLES, NUM_ANGLES, param);
if (errno) {
send_error("Failed to set parameters in parsed message.\n");
errno = SUCCESS;
return FAILURE;
/* ERROR HERE: Uncommented create_send_msg causes error.
create_send_msg(&out_msg);
if (errno) {
send_error("Failed to create and send message");
errno = SUCCESS;
return FAILURE;
return SUCCESS;
void braccio_arm::send_ack()
uint8_t ack[2] = {1, ACK};
serial.write(ack, 2);
void braccio_arm::send_finish()
uint8_t finish[2] = {1, FINISH};
serial.write(finish, 2);
int braccio_arm::send_print(const char *format, ...)
va_list args;
uint8_t set_msg[PARAM_BUFF];
va_start(args, format);
vsnprintf_check((char*)set_msg, PARAM_BUFF, format, args);
set_parsed_msg(&out_msg, PRINT_MSG, PRINT_GENERAL,
PARAM_STRLEN, set_msg);
if (errno) {
errno = SUCCESS;
return FAILURE;
if (errno) {
errno = SUCCESS;
return FAILURE;
va_end(args);
return SUCCESS;
int braccio_arm::send_error(const char *format, ...)
va_list args;
set_parsed_msg(&out_msg, PRINT_MSG, PRINT_ERROR,
if (errno) {
errno = SUCCESS;
return FAILURE;
if (errno) {
send_error("Failed to create and send message\n");
errno = SUCCESS;
return FAILURE;
va_end(args);
return SUCCESS;
int braccio_arm::send_verbose(const char *format, ...)
va_list args;
set_parsed_msg(&out_msg, PRINT_MSG, PRINT_VERBOSE,
if (errno) {
errno = SUCCESS;
return FAILURE;
if (errno) {
errno = SUCCESS;
return FAILURE;
va_end(args);
return SUCCESS;
int braccio_arm::set_parsed_msg(parsed_msg_s *fill, uint8_t msg_type,
uint8_t cmd, uint8_t param_len,
uint8_t *param)
int i;
int k;
fill->msg_type = msg_type;
fill->cmd = cmd;
// If i dont do fill->param_len here compiler complains it may not be init
fill->param_len = param_len;
if (param_len == PARAM_STRLEN) { // treat param as string of variable length
param_len = strnlen((char*)param, PARAM_BUFF); // excludes '\0'
if (param_len == PARAM_BUFF && param[param_len-1] != '\n')
return errno = EINVAL;
} else if (param_len > PARAM_BUFF) {
for (i=0, k=0; i < param_len; ++i, ++k)
fill->param[i] = param[k];
// exclude msg_size in size so reciever can parse 1 byte then parse the rest
fill->msg_size = param_len + MSG_SIZE_NO_PARAM - 1;
return SUCCESS;
int braccio_arm::parse_msg(uint8_t *msg, parsed_msg_s *in_msg)
uint8_t i = 0;
uint8_t k = 0;
// parse msg type
in_msg->msg_type = msg[i++];
// parse cmd type
in_msg->cmd = msg[i++];
// parse parameter length
in_msg->param_len = msg[i++];
if (in_msg->param_len > PARAM_BUFF)
// parse parameters
for (k=0; k < in_msg->param_len; ++k)
in_msg->param[k] = msg[i++];
// this is not sent by the python code but is set for initialization
in_msg->msg_size = in_msg->param_len + MSG_SIZE_NO_PARAM - 1;
return SUCCESS;
int braccio_arm::exec_command(parsed_msg_s *in_msg)
if (in_msg->msg_type != CMD_MSG)
switch (in_msg->cmd) {
case M1_ANGLE:
angles.m1 = check_angle(in_msg->param[0], M1_MIN_ANGLE, M1_MAX_ANGLE);
send_verbose("Changed M1 angle to %u\n", angles.m1);
case M2_ANGLE:
angles.m2 = check_angle(in_msg->param[0], M2_MIN_ANGLE, M2_MAX_ANGLE);
send_verbose("Changed M2 angle to %u\n", angles.m2);
case M3_ANGLE:
angles.m3 = check_angle(in_msg->param[0], M3_MIN_ANGLE, M3_MAX_ANGLE);
send_verbose("Changed M3 angle to %u\n", angles.m3);
case M4_ANGLE:
angles.m4 = check_angle(in_msg->param[0], M4_MIN_ANGLE, M4_MAX_ANGLE);
send_verbose("Changed M4 angle to %u\n", angles.m4);
case M5_ANGLE:
angles.m5 = check_angle(in_msg->param[0], M5_MIN_ANGLE, M5_MAX_ANGLE);
send_verbose("Changed M5 angle to %u\n", angles.m5);
case M6_ANGLE:
angles.m6 = check_angle(in_msg->param[0], M6_MIN_ANGLE, M6_MAX_ANGLE);
send_verbose("Changed M6 angle to %u\n", angles.m6);
case MX_ANGLE:
check_all_angles(in_msg->param[0], in_msg->param[1], in_msg->param[2],
in_msg->param[3], in_msg->param[4], in_msg->param[5]);
send_verbose("Changed all angles, "
"M1: %d, M2: %d, M3: %d, M4: %d, M5: %d, M6: %d\n",
angles.m1, angles.m2, angles.m3, angles.m4, angles.m5,
angles.m6);
case REQUEST_MX_ANGLE:
send_all_angles();
send_verbose("Sent all angles, "
angles.m6);
default:
send_verbose("Invalid command recieved.\n");
return SUCCESS;
int braccio_arm::create_send_msg(parsed_msg_s *msg)
io_msg_s to_send;
if (create_io_msg(msg, &to_send))
return FAILURE;
send_message(&to_send);
if (errno)
return FAILURE;
return SUCCESS;
int braccio_arm::create_io_msg(parsed_msg_s *msg, io_msg_s *io_msg)
uint8_t i = 0;
uint8_t k = 0;
io_msg->msg[i++] = msg->msg_size;
io_msg->msg[i++] = msg->msg_type;
io_msg->msg[i++] = msg->cmd;
if (msg->param_len > PARAM_BUFF)
io_msg->msg[i++] = msg->param_len;
for (k=0; k < msg->param_len; ++k)
io_msg->msg[i++] = msg->param[k];
io_msg->len = MSG_SIZE_NO_PARAM + k;
return SUCCESS;
int braccio_arm::send_message(io_msg_s *msg)
int ret;
ret = serial.write(msg->msg, msg->len);
if (ret != msg->len) {
errno = EIO;
return FAILURE;
return ret;
/* private functions */
uint8_t braccio_arm::check_angle(uint8_t angle, uint8_t min, uint8_t max)
if (angle < min)
return min;
if (angle > max)
return max;
return angle;
void braccio_arm::check_all_angles(uint8_t a1, uint8_t a2, uint8_t a3,
uint8_t a4, uint8_t a5, uint8_t a6)
angles.m1 = check_angle(a1, M1_MIN_ANGLE, M1_MAX_ANGLE);
angles.m2 = check_angle(a2, M2_MIN_ANGLE, M2_MAX_ANGLE);
angles.m3 = check_angle(a3, M3_MIN_ANGLE, M3_MAX_ANGLE);
angles.m4 = check_angle(a4, M4_MIN_ANGLE, M4_MAX_ANGLE);
angles.m5 = check_angle(a5, M5_MIN_ANGLE, M5_MAX_ANGLE);
angles.m6 = check_angle(a6, M6_MIN_ANGLE, M6_MAX_ANGLE);
int braccio_arm::vsnprintf_check(char *buff, int size, const char *format,
va_list args)
int num_written = 0;
num_written = vsnprintf(buff, size, format, args);
if (num_written > size-1) { // format was too large for buffer
send_error("Future message truncated, message was to long.");
return FAILURE;
return SUCCESS;
command_exec_test.ino (main)
* Program to test sending and recieving data from serial going through
* a command interface with braccio robot arm
* written by: James Ross
#define BAUD_RATE 115200
#define S_IN_BUFF 20 // serial input buffer size
uint8_t serial_in[S_IN_BUFF] = {'\0'};
braccio_arm braccio = braccio_arm(Serial);
// Serial.begin must be here since stream object doesnt contain begin()
Serial.begin(BAUD_RATE);
while (!Serial) {} // wait for serial interace to connect
// initialize the robot arm, goes to default position
braccio.init_arm();
braccio.send_verbose("Setup Complete\n");
parsed_msg_s parsed_msg;
if (braccio.serial_avail()){
braccio.serial_read(serial_in, S_IN_BUFF);
braccio.send_ack();
braccio.parse_msg(serial_in, &parsed_msg);
braccio.exec_command(&parsed_msg);
braccio.send_finish();
i know its alot of posted code, hopefully its not too hard to find the functions. I have a theory its about size but i am unsure since the dynamic memory goes from 38% to 40% but it does not even get to allocated alot of local variables.
Any ideas would be great. I am getting an Arduino Due to test it on as well.
