Arduino Door Lock Issues
Hi guys,
I am having issues with the following project; http://www.electronics123.net/amazon/projects/Electronics123_Door_Lock_Project/Arduino_Door_Lock.html
Here is the code
//You’ll see that we start with some constants.
const int buttonPin1 = 0;
const int buttonPin2 = 2;
const int buttonPin3 = 4;
const int buttonPin4 = 6;
const int buttonPinKill = 8;
const int RelayPin =  13;
const int LEDPin = 12;
/*These set up constant number values for the pins. They cannot be changed anywhere by the program.
Then we have variables:*/
int buttonState1 = 0;         // variable for reading the pushbutton status
int buttonState2 = 0;
int buttonState3 = 0;
int buttonState4 = 0;
int buttonState8 = 0;
int combCheckSum = 0;
//They can change
/* Next is the main setup method, it prepares the Arduino for the rest of the program by telling it which pins are used for what.
      // initialize the Relay pin and LED as outputs:
      pinMode(RelayPin, OUTPUT);
      pinMode(LEDPin, OUTPUT);
      // initialize the pushbutton pins as inputs:
      pinMode(buttonPin1, INPUT);
      pinMode(buttonPin2, INPUT);
      pinMode(buttonPin3, INPUT);
      pinMode(buttonPin4, INPUT);
      pinMode(buttonPinKill, INPUT);
//After the setup method comes the Main loop. This method gets run repeatedly thousands of times per minute. There is a lot to cover here so I will place comments throughout the code.
void loop(){
// read the state of the pushbuttons value:
  buttonState1 = digitalRead(buttonPin2);
  buttonState2 = digitalRead(buttonPin6);
  buttonState3 = digitalRead(buttonPin7);
  buttonState4 = digitalRead(buttonPin0);
  buttonState8 = digitalRead(buttonPinKill);
  // check if the pushbuttons are pressed.
  // if it is, the buttonState is HIGH:
/*The following waits for the first button to be pressed when pressed, it changes the value of the “combCheckSum” variable from 0 to 1000.*/
  if (buttonState1 == LOW) {
    combCheckSum = 1000;
/*then we check to see if any other buttons have been pressed, if so the checksum value is reset.*/
  if (buttonState8 == LOW) {
   combCheckSum = 0;
/*same as above only for button 2, it also checks to make sure button 1 is not still pressed, if all these statements return “TRUE” it makes the checksum 1200*/
if (buttonState2 == LOW) {
   if (buttonState1 == HIGH) {
     if (combCheckSum == 1000) {
       combCheckSum = 1200;
   else {
   combCheckSum = 0;
   combCheckSum = 0;
/*same as before, checking the state of button 3 this time. if these return TRUE checksum becomes 1230*/
if (buttonState3 == LOW) {
   if (buttonState2 == HIGH) {
      if (combCheckSum == 1200) {
         combCheckSum = 1230;
   else {
   combCheckSum = 0;
   combCheckSum = 0;
/*final check, looks at button 4, if all all the statements return TRUE the value of checksum becomes 1234.*/
if (buttonState4 == LOW) {
  if (buttonState3 == HIGH) {
   if (combCheckSum == 1230) {
   combCheckSum = 1234;
else {
   combCheckSum = 0;
   combCheckSum = 0;
/*unlock the door. if the following returns TRUE, the relay pin will become active and the door will unlock. It will stay unlocked for 3 seconds, or 3000 milliseconds, then close again.*/
if (combCheckSum == 1234) {
   digitalWrite(RelayPin, HIGH);
   delay(3000);
   digitalWrite(RelayPin, LOW);
   combCheckSum = 0;
And here is the error:
sketch_aug21a.ino: In function 'void loop()': sketch_aug21a:76: error: 'buttonPin6' was not declared in this scope sketch_aug21a:78: error: 'buttonPin7' was not declared in this scope sketch_aug21a:80: error: 'buttonPin0' was not declared in this scope
Please help!
Thanks in advance!
The error message says it all, you don't have buttonPin6 defined anywhere.
aeternus
