Arduino Driver let crash my computers
I made a 24Bit-DataAquistion with a Arduino Uno R3 and a LabView Program to collect the Data on the PC. Everything works fine for up to a quarter hour, but then a blue-screen is created. No mater whether the PC works with Windows 7, 8 or 8.1
The Arduino Driver installed is Version 1.0.0.0 taken from the IDE 1.5.6-r2 (beta) package at Port_#0002.Hub_#0003, LabView 2013 SP1 (32Bit) + NI-VISA 5.4.1
However, if I use a FTDI TTL-232R-5V USB to TTL converter connected to PIN 0 (RX) and PIN 1 (TX) in place of the Arduino USB connection data-collection over 18000s (5 hours) at a sampling rate of 50 ms works without this problem.
Any idea how to prevent blue screens with Arduinos own USB?
Here is an example of a message I get after restart of the PC.
Problemsignatur: Problemereignisname: BlueScreen Betriebsystemversion: 6.1.7601.2.1.0.256.4 Gebietsschema-ID: 1033
Zusatzinformationen zum Problem: BCCode: d1 BCP1: 00000000000000B8 BCP2: 0000000000000002 BCP3: 0000000000000000 BCP4: FFFFF8800AABE161 OS Version: 6_1_7601 Service Pack: 1_0 Product: 256_1
Dateien, die bei der Beschreibung des Problems hilfreich sind: C:\Windows\Minidump\051614-28017-01.dmp C:\Users\Peter Nyffeler\AppData\Local\Temp\WER-149261-0.sysdata.xml
Lesen Sie unsere Datenschutzbestimmungen online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0407
Wenn die Onlinedatenschutzbestimmungen nicht verf├╝gbar sind, lesen Sie unsere Datenschutzbestimmungen offline:
C:\Windows\system32\de-DE\erofflps.txt
