I'm trying to control an Arduino uno board using a DualShock 4, I'm having difficulty programming the joysticks "PS4.getAnalogHat(LeftHatY)" I want to control a motor using the joystick; I want to motor to go forward when I press up(++i), backward when I press down(--i), and no speed when I don't move the joystick. I'm able to move the motor in one direction and the speed increases but I can't the other direction to work. I can't seem make a connection between the joystick value (PS4.getAnalogHat(LeftHatY) > 137 || PS4.getAnalogHat(LeftHatY) < 117) and the motor values (0 - 255).
I'm using a USB Shield and a Motor Sheild
here's the code I have so far.
(Libray & void setup... etc)
void loop ()
Usb.Task();
if (PS4.connected())
if ( PS4.getAnalogHat(LeftHatY) > 137 || PS4.getAnalogHat(LeftHatY) < 117)
M3->setSpeed(PS4.getAnalogHat(LeftHatY));
PS4.setLed(Green);
PS4.setLedFlash(100 ,100);
if (PS4.getAnalogButton(R2))
M3->setSpeed(PS4.getAnalogButton(R2));
PS4.setLed(Yellow);
PS4.setLedFlash(50 , 50);
if (PS4.getButtonClick(CROSS))
M3->run(BACKWARD);
M3->setSpeed(255);
PS4.setLed(Blue);
PS4.setLedFlash(10, 10);
if (PS4.getButtonClick(CIRCLE))
M3->setSpeed(0);
PS4.setLed(Red);
PS4.setLedFlash(1 ,1);
will set the motor speed to a value greater than 137 or less than 117
Is that what you want or do you need a different range ?
I want the range to be from -255 to 255.
When I push the joystick down I want to have full backward (-255)
When I push the joystick up I want to have full forward (255)
when I don't move the joystick I want to have full stop (0)
the 137 and 117 come from the example I can't get it to work if I change these numbers .
So :
if the value is >137
output 255
if the value is < 117
output -255
output 0
Looks like a series of if/else tests to me
Thanks for the suggestion this is what I got:
if ( PS4.getAnalogHat(LeftHatY) > 137 )
M3->setSpeed(15);
M3->run(FORWARD);
PS4.setLed(Green);
if ( PS4.getAnalogHat(LeftHatY) < 117 )
M3->setSpeed(15);
M3->run(BACKWARD);
PS4.setLed(Yellow);
I get an error when I put:
else M3->setspeed(0);
I only get rotation in on direction but when I omit the else statement I the joystick working in both directions but it's continuous it won't stop when I don't move the joystick.
nevermind.
the else statement works!!!
my speed values were too low (couldn't register) I was using 15 instead of 255,
else M3->setSpeed(0); /////////works fine
if ( fix1 != PS4.getAnalogHat(LeftHatY) > 137 || fix2 != PS4.getAnalogHat(LeftHatY) < 117 )
M3->setSpeed(0); //////////boolean also works
Thanks A Lot!!!!!!!!!
return 0;
