Arduino Due access port denied
Hi all,
Been having problems getting a due to work. I used to use mine a year ago on IDE 1.6.8 and never had any problems setting it up apart from the usual beginner issues.
However I am having a lot of installation problems, listed below
  • on first upload, due seems to be uploading forever (latest IDE 1.8.something)
  • pressing upload again, I have an error with access port denied
Fixes I have tried
  • change port
  • check the board is correctly set
  • reinstall Arduino drivers
  • reinstall USB drivers
  • using IDE 1.6.6
  • using another laptop
  • using a different Due
  • trying atmega168 processor
  • trying different programmers
Problem was first found on my original Due's (had 1, busted it, bought another, forgot which was which so have tried both). Have bought another due and still having the same issues.
I have noticied that sometimes when I plug this new due in, it makes a high pitched noise... for people who think I may have broken it, I haven't sent any power back to itself, I have literally tried to make an led blink, so no direct/indirect 3.3/5v signals to any of the pins
I have uno's too but they work fine, using the same USB ports on the same laptops
I'm at a loss know as to the what the problem would be...
Any help would be greatly appreciated!!
Please do this with the first upload that seems to hang:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the process hangs up for good copy all the text from the black console window at the bottom of the Arduino IDE window. There will likely be more text than fits on the console window at the default size so you need to scroll up to see it all.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
The access port denied on the second upload is probably because the first upload process is still tying up the port.
This is what I got using the native port.
Had the same issue using the programming port.
Arduino: 1.8.3 (Windows 10), Board: "Arduino Duemilanove or Diecimila, ATmega328"
Sketch uses 928 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\Myf\AppData\Local\Temp\arduino_build_818317/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x72
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x72
avrdude done.  Thank you.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Just checked the verbose output of the compilation, works fine no errors that I could see
I was getting the same error. I'm an Arduino Noob so this may not be it but for me I had to change from COM1 to COM3 and everything worked fine.
Tools -> Port -> COM3
I even ran the blink led example :slight_smile:
unfortunately I have tried that :frowning:
tried all the usual answer I have seen from various posts but nothing has worked
