Arduino Due and 20x4 LCD Display not working
I am working on a project that will analog read some high voltage power supplies data and then print the data (voltage 0-10000V and Amperage 0-1ma) on an lcd screen. I have 2 displays both 20x4 with I2C connectivity the first is 2004A with an I2C Backpack that has a PCF8574. The second Display is a CFA634 20x4 I2C LCD CFA634 Data Page. The problem I have is that when I connect the first display to my code it works perfectly but when I connect the second display it just displays gibberish with the only code change being the address changing from 0x27 to 0x2A. Attached is my code as well as the GitHub to the libraries that I am using as well as the code that you can get from the manufacture of the display that works on an Arduino UNO that I don’t understand and doesn’t compile for the Arduino due. Also attached is the Github to a cfa632 library that compiles for Arduino UNO but doesn’t compile for Arduino due because it uses the software serial library and isn’t supported by the Due. Any guidance on the root of the problem or what info you need to help let me know as I am stuck. Thanks in advance and sorry for the wall of text.
My Code
//LCD Set up
#include <Wire.h>
LiquidCrystal_I2C lcd(0x2A, 20, 4);
//Power supply 1
  int PS1Vp = A0;
  int PS1Ap = A1;
  //Voltage
  int ARPS1V = 0;
  int PS1V = 0;
  //Amperage
  int ARPS1A = 0;
  int PS1A = 0;
//Power supply 2
  int PS2Vp = A2;
  int PS2Ap = A3;
  //Voltage
  int ARPS2V = 0;
  int PS2V = 0;
  //Amperage
  int ARPS2A = 0;
  int PS2A = 0;
//Power supply 3
  int PS3Vp = A4;
  int PS3Ap = A5;
  //Voltage
  int ARPS3V = 0;
  int PS3V = 0;
  //Amperage
  int ARPS3A = 0;
  int PS3A = 0;
//Power supply 4
  int PS4Vp = A6;
  int PS4Ap = A7;
  //Voltage
  int ARPS4V = 0;
  int PS4V = 0;
  //Amperage
  int ARPS4A = 0;
  int PS4A = 0;
 // Set Up and setting values
 analogReadResolution(12);
 //LCD setup cont.
 lcd.begin();
 lcd.backlight();
 lcd.clear();
 // Power Supply 1
  pinMode(PS1Vp, INPUT);
  pinMode(PS1Ap, INPUT);
 // Power Supply 2
  pinMode(PS2Vp, INPUT);
  pinMode(PS2Ap, INPUT);
  // Power Supply 3
  pinMode(PS3Vp, INPUT);
  pinMode(PS3Ap, INPUT);
  // Power Supply 4
  pinMode(PS4Vp, INPUT);
  pinMode(PS4Ap, INPUT);
 //Power supply 1-------------------------------------------------------------------------------
  // Voltage
  ARPS1V = analogRead(PS1Vp);
  PS1V = map(ARPS1V, 0, 4095, 0, 10000);
  Serial.print("PS1 ");
  Serial.print (PS1V);
  Serial.print ("V ");
  //Amperage
  ARPS1A = analogRead(PS1Ap);
  PS1A = map(ARPS1A, 0, 4095, 0, 1000);
  Serial.print (PS1A);
  Serial.println ("uA");
  // LCD printing for Power Supply 1
      lcd.setCursor(0,0);
      lcd.print("PS1 ");
      // PS1 Voltage
      if (PS1V<10){
        lcd.print("    ");
      else if (PS1V<100){
        lcd.print("   ");
      else if (PS1V<1000){
        lcd.print("  ");
      else if (PS1V<10000){
        lcd.print(" ");
      lcd.print(PS1V);
      lcd.print("V ");
      // PS 1 Amperage
      if (PS1A<10){
        lcd.print("   ");
      else if (PS1A<100){
        lcd.print("  ");
      else if (PS1A<1000){
        lcd.print(" ");
      lcd.print(PS1A);
      lcd.print("uA");
 //Power supply 2-------------------------------------------------------------------------------
  // Voltage
  ARPS2V = analogRead(PS2Vp);
  PS2V = map(ARPS2V, 0, 4095, 0, 10000);
  Serial.print("PS2 ");
  //Amperage
  ARPS2A = analogRead(PS2Ap);
  PS2A = map(ARPS2A, 0, 4095, 0, 1000);
  Serial.print (PS2A);
  // LCD printing for Power Supply 2
      lcd.setCursor(64,0);
      lcd.print("PS2 ");
      // PS2 Voltage
      if (PS2V<10){
        lcd.print("    ");
      else if (PS2V<100){
        lcd.print("   ");
      else if (PS2V<1000){
        lcd.print("  ");
      else if (PS2V<10000){
        lcd.print(" ");
      lcd.print(PS2V);
      lcd.print("V ");
      // PS 2 Amperage
      if (PS2A<10){
        lcd.print("   ");
      else if (PS2A<100){
        lcd.print("  ");
      else if (PS2A<1000){
        lcd.print(" ");
      lcd.print(PS2A);
      lcd.print("uA");
 //Power supply 3-------------------------------------------------------------------------------
  // Voltage
  ARPS3V = analogRead(PS3Vp);
  PS3V = map(ARPS3V, 0, 4095, 0, 10000);
  Serial.print("PS3 ");
  Serial.print (PS3V);
  //Amperage
  ARPS3A = analogRead(PS3Ap);
  PS3A = map(ARPS3A, 0, 4095, 0, 1000);
  Serial.print (PS3A);
  // LCD printing for Power Supply 3
      lcd.setCursor(20,0);
      lcd.print("PS3 ");
      // PS3 Voltage
      if (PS3V<10){
        lcd.print("    ");
      else if (PS3V<100){
        lcd.print("   ");
      else if (PS3V<1000){
        lcd.print("  ");
      else if (PS3V<10000){
        lcd.print(" ");
      lcd.print(PS3V);
      lcd.print("V ");
      // PS 3 Amperage
      if (PS3A<10){
        lcd.print("   ");
      else if (PS3A<100){
        lcd.print("  ");
      else if (PS3A<1000){
        lcd.print(" ");
      lcd.print(PS3A);
      lcd.print("uA");
 //Power supply 4-------------------------------------------------------------------------------
  // Voltage
  ARPS4V = analogRead(PS4Vp);
  PS4V = map(ARPS4V, 0, 4095, 0, 10000);
  Serial.print("PS4 ");
  Serial.print (PS4V);
  //Amperage
  ARPS4A = analogRead(PS4Ap);
  PS4A = map(ARPS4A, 0, 4095, 0, 1000);
  Serial.print (PS4A);
  // LCD printing for Power Supply 4
      lcd.setCursor(84,0);
      lcd.print("PS4 ");
      // PS4 Voltage
      if (PS4V<10){
        lcd.print("    ");
      else if (PS4V<100){
        lcd.print("   ");
      else if (PS4V<1000){
        lcd.print("  ");
      else if (PS4V<10000){
        lcd.print(" ");
      lcd.print(PS4V);
      lcd.print("V ");
      // PS 4 Amperage
      if (PS4A<10){
        lcd.print("   ");
      else if (PS4A<100){
        lcd.print("  ");
      else if (PS4A<1000){
        lcd.print(" ");
      lcd.print(PS4A);
      lcd.print("uA");
 Serial.println("");
 delay(250);
GitHub Library for the i2c LCD library I am using.
I2C Liquid Crystal Library
This is the Code that the Manufacture's guide that works on an Arduino Uno that I don’t understand and doesn’t compile for the Arduino due.
Link To manufactures build instructions Chrystalfontz guide
// This is an example use of the Crystalfontz CFA634 I2C 20x4 LCD, driven by
// an Arduino Uno or Seeeduino v4.2 set to 5v.
// The demonstration shows menus (stored in flash / PROGMEM) and bar graphs.
// Wiring information is available in our forum:
//  https://forum.crystalfontz.com/showthread.php/7483
// There is a video of the operation in action on YouTube:
//  https://www.youtube.com/watch?v=lsuUchaF-FM
//  2018 - 11 - 01 Brent A. Crosby / Crystalfontz
// Display is Crystalfontz CFA634-TFH-KC
//   https://www.crystalfontz.com/product/cfa634tfhkc
//This is free and unencumbered software released into the public domain.
//Anyone is free to copy, modify, publish, use, compile, sell, or
//distribute this software, either in source code form or as a compiled
//binary, for any purpose, commercial or non-commercial, and by any
//means.
//In jurisdictions that recognize copyright laws, the author or authors
//of this software dedicate any and all copyright interest in the
//software to the public domain. We make this dedication for the benefit
//of the public at large and to the detriment of our heirs and
//successors. We intend this dedication to be an overt act of
//relinquishment in perpetuity of all present and future rights to this
//software under copyright law.
//THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
//EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
//MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
//IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR
//OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
//ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
//OTHER DEALINGS IN THE SOFTWARE.
//For more information, please refer to <http://unlicense.org/>
#include <Arduino.h>
#include <Wire.h>  //I2C library
//   ARD      | Port | LCD           | Color | Note
//  SCL       |  PC5 | I2C SCL Clock | Blue  | (5K resistor pull up to 5v)
//  SDA       |  PC4 | I2C SDA Data  | Green | (5K resistor pull up to 5v)
#define CFA_634_I2C_ADDRESS  (42)
#define USE_PRINTF //Saves ~1600 bytes
#ifdef USE_PRINTF
// ref http://playground.arduino.cc/Main/Printf
#include <stdarg.h>
void SerPrintFF(const __FlashStringHelper *fmt, ... )
  char
    tmp[128]; // resulting string limited to 128 chars
  va_list
    args;
  va_start(args, fmt );
  //vsnprintf_P(tmp, 128, (const char *)fmt, args);
  va_end (args);
  Serial.print(tmp);
#endif
// ref http://scott.dd.com.au/wiki/Arduino_Static_Strings
void SerialPrint_P(const char flash_string[])
  uint8_t
    c;
  for(;0x00 != (c = pgm_read_byte(flash_string)); flash_string++)
    Serial.write(c);
//This does not depend on printf so it is small
void I2C_String_XY(uint8_t col, uint8_t row,
                   const __FlashStringHelper *flash_string )
   //Start the I2C transaction
  Wire.beginTransmission(CFA_634_I2C_ADDRESS);
  //Move the cursor to col,row
  Wire.write(17);
  Wire.write(col);
  Wire.write(row);
  //Pipe out the string, up to but not incuding the null terminator
  uint8_t
    this_character;
  //Get an editable copy of the flash string pointer
  const char
    *ptr;
  ptr=(const char *)flash_string;
  //Grab the next character from the flash string. If it is not
  //null, send it out.
  while(0 != (this_character=pgm_read_byte(ptr)))
    Wire.write(this_character);
    //Point to the next character in RAM
    ptr++;
  //Stop the I2C transaction
  Wire.endTransmission();
  //Give the display a little time to deal with its new life situation.
  delay(3);
void I2C_show_dec3_XY(uint8_t col, uint8_t row,uint8_t input)
  Wire.write(17);
  Wire.write(col);
  Wire.write(row);
  uint8_t
    digit;
  uint8_t
    no_blank;
  digit=input/100U;
  if(digit != 0U)
    Wire.write(digit+(uint8_t)'0');
    no_blank=1U;
    Wire.write((uint8_t)' ');
    no_blank=0U;
  input%=100U;
  /*lint --e(1960)*/
  digit=input/10U;
  if((digit|no_blank) != 0U)
  Wire.write((input%10U) + (uint8_t)'0');
  //Give the display some time to process the command
  delay(1);
#ifdef USE_PRINTF
void I2CPrintFFXY(uint8_t col, uint8_t row,
  //Use variable arguments to format the string
  //this includes printf lib which is big
  char
    tmp[40]; // resulting string limited to 128 chars
  va_list
    args;
  //vsnprintf_P(tmp, 40, (const char *)fmt, args);
  va_end (args);
  //Send the formatted string to the display
  Wire.write(17);
  Wire.write(col);
  Wire.write(row);
  uint8_t
    this_character;
  //Get a pointer into the formatted string on the stack
  char
    *ptr;
  ptr=&tmp[0];
  while(0 != (this_character=*ptr))
    ptr++;
  delay(1);
#endif
void Bar_Graph(uint8_t graph_index,
               uint8_t style,
               uint8_t start_column,
               uint8_t end_column,
               uint8_t bar_length,
               uint8_t row)
#if 1
  //Use built-in bar graph command
  //Bar command
  Wire.write(18);
  Wire.write(graph_index);
  Wire.write(style);
  Wire.write(start_column);
  Wire.write(end_column);
  Wire.write(bar_length);
  Wire.write(row);
  delay(5);
#else
  //Or do it the old fashioned way.
  //The first character will be varaible width.
  //Set the second character to full width.
  Wire.write(25); //custom character command
  Wire.write((graph_index<<1)+1);
  Wire.write(style & 0x80 ? 0x7F : 0); //Top Line
  Wire.write(style & 0x40 ? 0x7F : 0);
  Wire.write(style & 0x10 ? 0x7F : 0);
  Wire.write(style & 0x20 ? 0x7F : 0);
  Wire.write(style & 0x08 ? 0x7F : 0);
  Wire.write(style & 0x04 ? 0x7F : 0);
  Wire.write(style & 0x02 ? 0x7F : 0);
  Wire.write(style & 0x01 ? 0x7F : 0); //Bottom Line
  delay(1);
  uint8_t
    i;
  //Write the characters in the bar area. The full width to the left,
  //the variable width character, then blanks.
  Wire.write(17);
  Wire.write(row);
  //Fill in the solid characters.
  for(i=start_column;i<(bar_length/6);i++)
    //Second special character (solid);
    Wire.write(128+(graph_index<<1)+1);
  //Put in the partial, variable character
  Wire.write(128+(graph_index<<1));
  //Fill the rest of the area with blanks
  for(i++;i<=end_column;i++)
    Wire.write(' ');
  delay(1);
  //Now set the partial bar width to the remainder
  uint8_t
    horizontal_mask;
  horizontal_mask = (0x3F << (6-(bar_length%6)) & 0x3F);
  Wire.write((graph_index<<1));
  Wire.write(style & 0x80 ? horizontal_mask : 0); //Top Line
  Wire.write(style & 0x40 ? horizontal_mask : 0);
  Wire.write(style & 0x10 ? horizontal_mask : 0);
  Wire.write(style & 0x20 ? horizontal_mask : 0);
  Wire.write(style & 0x08 ? horizontal_mask : 0);
  Wire.write(style & 0x04 ? horizontal_mask : 0);
  Wire.write(style & 0x02 ? horizontal_mask : 0);
  Wire.write(style & 0x01 ? horizontal_mask : 0); //Bottom Line
  delay(1);
#endif
void Bar_Graph_Demo(void)
  //Build up the base screen
  //Clear the LCD
  Wire.write(12);
  delay(3);
  //                  "01234567890123456789"
  I2C_String_XY(0,0,F("Speed:       123 kph"));
  I2C_String_XY(0,2,F("Temperature: 123 oC "));
  //Insert the superscript 0 for degree
  I2C_String_XY(17,2,F("\x1E\x01\x80"));
  uint8_t
    speed_position;
  uint8_t
    speed_direction;
  speed_position=0;
  speed_direction=1;
  uint16_t
    updates;
  for(updates=0;updates<1000;updates++)
#ifdef USE_PRINTF
    //Print the speed, numeric value
    I2CPrintFFXY(13,0,F("%3d"),speed_position);
    //Print the temp, numeric value
    I2CPrintFFXY(13,2,F("%3d"),80+(speed_position/6));
#else
    I2C_show_dec3_XY(13,0,speed_position);
    ///Print the temp, numeric value
    I2C_show_dec3_XY(13,2,80+(speed_position/6));
#endif
    //Draw speed bar. 1px = 2KMH
    Bar_Graph(0,                //graph_index
              0x7E,             //style
              0,                //start_column,
              19,               //end_column,
              speed_position/2, //bar_length,
              1);               //row
    //Draw Temp 1px = 1 deg C
    Bar_Graph(1,                     //graph_index
              0x3C,                  //style
              0,                     //start_column,
              19,                    //end_column,
              80+(speed_position/6), //bar_length,
              3);                    //row
    if(speed_direction)
      //speeding up
      if(speed_position<239)
        speed_position++;
        //start slowing down
        speed_direction=0;
      //slowing down
      if(48<speed_position)
        speed_position--;
        //start speeding up
        speed_direction=1;
// Menu Data in flash
// ref: https://playground.arduino.cc/Main/PROGMEM
const char Menu_Item_00[] PROGMEM = "Red";
const char Menu_Item_01[] PROGMEM = "Orange";
const char Menu_Item_02[] PROGMEM = "Yellow";
const char Menu_Item_03[] PROGMEM = "Green";
const char Menu_Item_04[] PROGMEM = "Blue";
const char Menu_Item_05[] PROGMEM = "Purple";
const char Menu_Item_06[] PROGMEM = "Brown";
const char Menu_Item_07[] PROGMEM = "Magenta";
const char Menu_Item_08[] PROGMEM = "Tan";
const char Menu_Item_09[] PROGMEM = "Cyan";
const char Menu_Item_10[] PROGMEM = "Olive";
const char Menu_Item_11[] PROGMEM = "Maroon";
const char Menu_Item_12[] PROGMEM = "Navy";
const char Menu_Item_13[] PROGMEM = "Silver";
const char Menu_Item_14[] PROGMEM = "Lime";
const char Menu_Item_15[] PROGMEM = "Teal";
const char Menu_Item_16[] PROGMEM = "Indigo";
const char Menu_Item_17[] PROGMEM = "Violet";
const char Menu_Item_18[] PROGMEM = "Pink";
const char Menu_Item_19[] PROGMEM = "Black";
const char Menu_Item_20[] PROGMEM = "White";
const char Menu_Item_21[] PROGMEM = "Gray";
//Flash array of pointers to access the unequal length strings in flash above.
const char * const Menu_Strings[22] PROGMEM = {
  Menu_Item_00,Menu_Item_01,Menu_Item_02,Menu_Item_03,Menu_Item_04,Menu_Item_05,Menu_Item_06,
  Menu_Item_07,Menu_Item_08,Menu_Item_09,Menu_Item_10,Menu_Item_11,Menu_Item_12,Menu_Item_13,
  Menu_Item_14,Menu_Item_15,Menu_Item_16,Menu_Item_17,Menu_Item_18,Menu_Item_19,Menu_Item_20,
  Menu_Item_21};
void Menu_Demo_Show_Choices(uint8_t top_choice)
  uint8_t
    line;
  for(line=0;line<=3;line++)
    Wire.write(17);
    Wire.write(11);   //col
    Wire.write(line); //row
    uint8_t
      this_character;
    const char
      *ptr;
    ptr=(char*)pgm_read_word(&(Menu_Strings[top_choice+line]));
    //Keep track of the number of trailing blanks that we need
    //to send. The menu field is 8 wide.
    uint8_t
      trailing_blanks_needed;
    trailing_blanks_needed=8;
      ptr++;
      //We need one less trailing blank.
      trailing_blanks_needed--;
    while(trailing_blanks_needed)
      Wire.write(' ');
    delay(3);
void Menu_Demo_Base_screen(void)
  //Clear the LCD
  Wire.write(12);
  delay(3);
  //                  "Use ud to >magenta <"
  //                  "to choose |red     |"
  //                  "the color |pink    |"
  //                  "e to set. |hot pink|"
  I2C_String_XY(0,0,F("Use \xDE\xE0 to           "));
  I2C_String_XY(0,1,F("to choose           "));
  I2C_String_XY(0,2,F("the color           "));
  I2C_String_XY(0,3,F("\x1E\x01\x1C to set.           "));
void Menu_Demo_Set_Highlight_Line(uint8_t active_line)
  uint8_t
    line;
    I2C_String_XY(10,line,(line == active_line)?F("\x1E\x01\x10"):F("\xFE"));
    I2C_String_XY(19,line,(line == active_line)?F("\x1E\x01\x11"):F("\xFE"));
void Menu_Demo(void)
  Menu_Demo_Base_screen();
  //The item selected 0~21
  uint8_t
    menu_position;
  uint8_t
    menu_direction;
  //The line the pointers are on 0~3
  uint8_t
    pointer_position;
  menu_position=0;
  menu_direction=1;
  pointer_position=0;
  uint16_t
    updates;
  for(updates=0;updates<70;updates++)
    Menu_Demo_Show_Choices(menu_position-pointer_position);
    Menu_Demo_Set_Highlight_Line(pointer_position);
    delay(400);
    if(menu_direction)
      //moving down in the list
      if(menu_position < 21)
        menu_position++;
        if(pointer_position<3)
          pointer_position++;
        //start moving back up
        menu_direction=0;
      //moving up in the list
      if(0 < menu_position)
        menu_position--;
        if(0<pointer_position)
          pointer_position--;
        //start moving back down
        menu_direction=1;
    }  //for updates
  //Debug output (Ctrl+shift+M)
  Serial.begin(115200);  // start serial for output
#ifdef USE_PRINTF
  SerPrintFF(F("Begin (with printf)\n"));
#else
  Serial.println("Begin (no printf)");
#endif
  //Enable/configure I2C
  Wire.begin();
  //Give it time to boot, in case we are coming from power-up.
  //Reboot, just in case the last time we ran the code we left the
  //display all messed up, and we were not power-cycled.
  Wire.write(' ');
  Wire.write(' ');
  Wire.write(' ');
  Wire.write(' ');
  Wire.write(' ');
  Wire.write(' ');
  Wire.write(' ');
  Wire.write(' ');
  Wire.write(' ');
  Wire.write(26);
  Wire.write(26);
  //Give it time to re-boot
  delay(80);
  // (Optional) Delay to see the logo screen
  delay(2000);
  //Default settings for our demo
  //Hide the cursor
  Wire.write(4);
  //Turn Scroll Off
  Wire.write(20);
  //Turn Wrap Off
  Wire.write(24);
  //Clear the LCD
  Wire.write(12);
  //Give it time to clear
  delay(5);
  Menu_Demo();
  Bar_Graph_Demo();
Git Hub for the Library
LCD I2c Library
I2C Address Finder
// i2c_scanner
// Version 1
//    This program (or code that looks like it)
//    can be found in many places.
//    For example on the Arduino.cc forum.
//    The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
//     Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26  2013
//    V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
//    by Arduino.cc user Krodal.
//    Changes by louarnold removed.
//    Scanning addresses changed from 0...127 to 1...119,
//    according to the i2c scanner by Nick Gammon
//    https://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
//    As version 4, but address scans now to 127.
//    A sensor seems to use address 120.
// Version 6, November 27, 2015.
//    Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
  Wire.begin();
  while (!Serial);             // Leonardo: wait for serial monitor
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
Link To the CFA632 Library with Examples Library Link
There is a Youtube video of a CFA634 on a Seeeduino. https://www.crystalfontz.com/product/cfa634tfhkc-i2c-20x4-character-module
This is the source code https://www.crystalfontz.com/products/document/4039/I2C_634_Test.zip
Note that these "intelligent" I2C/SPI/UART displays have non-standard commands.
e.g. CrystalFontz, NHD, ...
They are completely different to a PCF8574 backpack library.
And completely different to a native-I2C-interface library (as used by some COG controllers)
Run the CrystalFontz demo sketch. Then adapt for your project.
David.
Ok thank you I will take a look and see what I can do.
