I will use ESP32 to get the file from the server and upload the code to the Arduino due to it is an idea. is there any possibility of making it work? if there I can get suggestions to achieve it.
What task will the Due perform that the ESP32 cannot perform without the Due?
ESP32 code can be updated remotely, through WiFi ("Over The Air" = OTA)
yes I need due since there are many I/O and other communications so i am using due(since that are not avalibe in esp32)
I/O of ESP can be increased with use of i2c or SPI expansion chips.
What "other communications" ?
No, I need to have I2C and SPI to communicate with other devices. so I found Arduino GIGA.
you can communicate with multiple devices using I2C and SPI busses - try a web search for i2c and SPI - you will get plenty of links comparing and describing how the protocols operate
i will have multiple devices and the address in I2C or not that many so i will go with giga.
It's clear you are not open to suggested advice. Good luck with your project.
