Arduino due and ethernet shield 1.1
I have Arduino Due and Ethernet shield 1.1. I have 2 questions: 1) Does the SPI connectors should be connected together? If so, why doesn't it have built in connectors? 2) Why the Ethernet.h library doesn't work this shield 1.1?
Hope for reply
Does anyone had those problems?
barakpn: Does anyone had those problems?
Yes. Everyone who has a ENC28J60 ethernet chip that tries the W5100 library has the same fail. You must use a library for that IC.
edit: Also, the Due is 3.3v, not 5v. That could cause a problem.
Thanks SurferTim for the replay.
I tried to download the ENC28J60 libraries. After that, the code don't compile. only more errors.
Where is my mistake? Do you have a sample?
