Arduino Due and LSM303DLHC. More I2C issues?
So, I'm trying to get my Due to connect to an LSM303DLHC.
Pin Assignment (LSM303DLHC : DUE)
SCL:SCL
SDA:SDA
VIN:3.3V
GND:GND
I'm using the library downloaded from: GitHub - pololu/lsm303-arduino: Arduino library for Pololu LSM303 boards
According to the read me / description. The Arduino Due's wire library does not allow the init() method to be called without specifying what breakout board you are using. So, I've done that and set sa0_high (I've tried all 3).
I have a friend who is using this same breakout board and it works well with the omega. I might check with him to see if our breakout board is damaged. But I feel like it may be an issue with the library / code? Anyone have any hints?
#include <Wire.h>
#include <LSM303.h>
LSM303 compass;
LSM303::vector<int16_t> running_min = {32767, 32767, 32767}, running_max = {-32768, -32768, -32768};
char report[80];
  Wire.begin();
  compass.init(LSM303::device_DLHC, LSM303::sa0_high);
  compass.enableDefault();
  compass.read();
  running_min.x = min(running_min.x, compass.m.x);
  running_min.y = min(running_min.y, compass.m.y);
  running_min.z = min(running_min.z, compass.m.z);
  running_max.x = max(running_max.x, compass.m.x);
  running_max.y = max(running_max.y, compass.m.y);
  running_max.z = max(running_max.z, compass.m.z);
  snprintf(report, sizeof(report), "min: {%+6d, %+6d, %+6d}    max: {%+6d, %+6d, %+6d}",
    running_min.x, running_min.y, running_min.z,
    running_max.x, running_max.y, running_max.z);
  Serial.println(report);
  delay(100);
My output shows: min: { +0, +0, +0} max: { +0, +0, +0}
  • infinity.
Have you tried connecting to SDA1 and SCL1
You know, I should have tried that last night too.
That's just a wire1() call right?
I'll give it a shot when in a few hours.
Try this:
#include <Wire.h>
#include <LSM303.h>
LSM303 compass;
LSM303::vector running_min = {32767, 32767, 32767}, running_max = {-32768, -32768, -32768};
  Wire.begin();
  compass.init(LSM303DLHC_DEVICE, LSM303_SA0_A_HIGH);
  compass.read();
  Serial.print("M min ");
  Serial.print("X: ");
  Serial.print((int)running_min.x);
  Serial.print(" Y: ");
  Serial.print((int)running_min.y);
  Serial.print(" Z: ");
  Serial.print((int)running_min.z);
  Serial.print(" M max ");
  Serial.print((int)running_max.x);
  Serial.print((int)running_max.y);
  Serial.println((int)running_max.z);
  delay(100);
Palliser:
Try this:
#include <Wire.h>
#include <LSM303.h>
LSM303 compass;
 Wire.begin();
 compass.read();
 delay(100);
I tried using LSM303DLHC_DEVICE instead of LSM303::device_DLHC last night. The library complains about it. Inside the libraries keywords.txt it's no longer LSM303DLHC_DEVICE as the library online says. It's device_DLHC. Same with the sa0 high / low.
From the keywords.txt file:
device_DLH LITERAL1
device_DLM LITERAL1
device_DLHC LITERAL1
device_D LITERAL1
device_auto LITERAL1
sa0_low LITERAL1
sa0_high LITERAL1
sa0_auto LITERAL1
Updated: Just plugged the LSM303DLHC into an Arduino Mega (2560), and ran the sample code and it worked flawlessly. It's definitely and issue with the libraries / Due. Tried the SCL1 / SDA1, but I think the compasses INIT() method defaults the use to the SDA / SCL on all boards.
Given that this LSM303 library was built for AVR devices, I'd recommend you to change in LSM303.h
the line: #include <Arduino.h> for #include <variant.h> . Sadly I don't have a device at hand to help you more.
Good luck.
P
