Arduino Due and MI0283QT-2 from Watterott
it's the first time for me I'm using an Arduino and I only have a few experence in progromming.
I try to use the touch functionality of my MI0283QT-2 from www.watterott.com. The libs are already provided by watterott but it doesn't work as expected.
The EEPROM part is not used because it's not supported by the Due. The text and blacklight is working fine but the touch function is not working.
I observed the returned values from the lcd.touchread() function and the touchZ value is always 127.
I think this represents the presure on the screen (?).
Before I buy a new display I want to be sure that the display is not working and its not a problem of (the code or) my modifications.
Does someone have an idea why its not working?
  Paint Demonstration
//#include <EEPROM.h>
#include <Wire.h>
#include <SPI.h>
#include <digitalWriteFast.h>
#include <GraphicsLib.h>
#include <MI0283QT2.h>
#include <MI0283QT9.h>
#include <DisplaySPI.h>
#include <DisplayI2C.h>
//Declare only one display !
 MI0283QT2 lcd;  //MI0283QT2 Adapter v1
// MI0283QT9 lcd;  //MI0283QT9 Adapter v1
// DisplaySPI lcd; //SPI (GLCD-Shield or MI0283QT Adapter v2)
// DisplayI2C lcd; //I2C (GLCD-Shield or MI0283QT Adapter v2)
void writeCalData(void)
  uint16_t i, addr=0;
  uint8_t *ptr;
  EEPROM.write(addr++, 0xAA);
  ptr = (uint8_t*)&lcd.tp_matrix;
  for(i=0; i < sizeof(CAL_MATRIX); i++)
    EEPROM.write(addr++, *ptr++);
  return;
uint8_t readCalData(void)
  uint16_t i, addr=0;
  uint8_t *ptr;
  uint8_t c;
  c = EEPROM.read(addr++);
  if(c == 0xAA)
      *ptr++ = EEPROM.read(addr++);
    return 0;
  return 1;
  //init display
  lcd.begin(7); //spi-clk=SPI_CLOCK_DIV4
  //lcd.begin(SPI_CLOCK_DIV2); //spi-clk=SPI_CLOCK_DIV2
  //lcd.begin(SPI_CLOCK_DIV4, 8); //SPI Displays: spi-clk=Fcpu/4, rst-pin=8
  //lcd.begin(0x20); //I2C Displays: addr=0x20
  //lcd.begin(0x20, 8); //I2C Displays: addr=0x20, rst-pin=8
  //set touchpanel calibration data
  lcd.touchRead();
  Serial.print("\nTouchX: ");
  Serial.print(lcd.touchX());
  Serial.print("\nTouchY: ");
  Serial.print(lcd.touchY());
  Serial.print("\nTouchZ: ");
  Serial.print(lcd.touchZ());
  if(lcd.touchZ())  // || readCalData()) //calibration data in EEPROM?
    lcd.touchStartCal(); //calibrate touchpanel
//    writeCalData(); //write data to EEPROM
  //clear screen
  lcd.fillScreen(RGB(255,255,255));
  //show backlight power and cal text
  lcd.led(50); //backlight 0...100%
  lcd.drawText(2, 2, "BL    ", RGB(255,0,0), RGB(255,255,255), 1);
  lcd.drawInteger(20, 2, 50, DEC, RGB(255,0,0), RGB(255,255,255), 1);
  lcd.drawText(lcd.getWidth()-30, 2, "CAL", RGB(255,0,0), RGB(255,255,255), 1);
  char tmp[128];
  static uint16_t last_x=0, last_y=0;
  static uint8_t led=60;
  unsigned long m;
  static unsigned long prevMillis=0;
  //service routine for touch panel
  lcd.touchRead();
  if(lcd.touchZ()) //touch press?
    //change backlight power
    if((lcd.touchX() < 45) && (lcd.touchY() < 15))
      m = millis();
      if((m - prevMillis) > 800) //change only every 800ms
        prevMillis = m;
        led += 10;
        if(led > 100)
          led = 10;
        lcd.led(led);
        lcd.drawInteger(20, 2, led, DEC, RGB(255,0,0), RGB(255,255,255), 1);
    //calibrate touch panel
    else if((lcd.touchX() > (lcd.getWidth()-30)) && (lcd.touchY() < 15))
//      writeCalData();
    //draw line
    else if((last_x != lcd.touchX()) || (last_y != lcd.touchY()))
      sprintf(tmp, "X:%03i Y:%03i P:%03i", lcd.touchX(), lcd.touchY(), lcd.touchZ());
      lcd.drawText(50, 2, tmp, RGB(0,0,0), RGB(255,255,255), 1);
      if(last_x == 0)
        lcd.drawPixel(lcd.touchX(), lcd.touchY(), RGB(0,0,0));
        lcd.drawLine(last_x, last_y, lcd.touchX(), lcd.touchY(), RGB(0,0,0));
      last_x = lcd.touchX();
      last_y = lcd.touchY();
    last_x = 0;
The code based on an example provided by watterott.
I think the problem is that the SPI speed is to high for the ADS7846 touch controller. I have updated the lib, so that speed will be slower also on non-AVR microcontrollers.
Rgds,
Andreas
thanks for the quichupdate. Now mostly everythink works fine.
But as always there is a small "but". The value for touchZ seems to be correct but touchX and touchY are always "0".
I will try to find a solution the next days, hopefully.
Regards,
Carsten
touchX() and touchY() will be zero, if there is no calibration data.
The variables tp_x + tp_y are the raw position values:
Rgds,
Andreas
