I tried the serial terminal in arduino due, the serial monitor does not activate. I program with the listing below, launch a normal serial terminal and everything works fine. Where am I wrong? `void setup() { Serial.begin(9600); }
void loop() { Serial.println("Hello world! Jack"); delay(1000); }`
Make sure your terminal matches the 9600 baud rate. Do you get ANYTHING? Garbled data = wrong bauid rate/comm format (8N1)
Thanks for replay, 9600 baud rate is correct, the arduino due monitor does not open.
I have used this procedure :https://docs.arduino.cc/software/ide-v2/tutorials/ide-v2-serial-monitor
