ARDUINO DUE and Simulink Change Resolution and PWM Frequency
Hello, i use for many projects an Arduino BOARD.
Currently, i use the ARDUINO DUE with Simulink.
My Question to you as Arduino- Profis :) :
Please, i search for a long time, but find an answer.
How can i change the PWM Frequency from Simulink ?
With my Arduino Mega, when i use the INITIALIZE Function in Simulink and write this :
TCCR2B = TCCR2B & 0b11111000
I change my PWM-Frequence to 32kHz, but how is the code for the Arduino DUE?
And how can i change the PWM Resolution from Simulink to ?
Does it know someone ?
Try the "pwm01.h" library:
http://forum.arduino.cc/index.php?topic=144446.msg1149044#msg1149044
Thanks for your answer, but this libary is for the Arduino IDE, how can i implement this in SImulink?
No, it's for any C++ compiler.
If Simulink isn't compiling C code, then you will have to look at the functions in the library file and copy what it is doing.
