Arduino Due - CANbus - pins RX0 TX0
I need to connect a "TJA1050 High speed CAN transceiver" to "Arduino Due".
I'm sure it would work if I connected TJA1050 to Arduino Due pins "CANRX and CANTX".
Is there a way to make it work connecting TJA1050 to Arduino Due using pins "RX0 and TX0" instead of pins "CANRX and CANTX"?
I already designed a custom PCB shield with connections using pins "RX0" and "TX0", so it would be really of help if I didn't had to start from scratch the PCB project.
Is there a way to make it work connecting TJA1050 to Arduino Due using pins “RX0 and TX0” instead of pins “CANRX and CANTX”?
No. The UART interface and the CAN bus are not physically compatible.
Ok, I'd better accept the reality and design a new PCB.
Thank you very much
