No matter which simple sample I try, compiling fails (so does uploading)
Any help appreciated.
Arduino: 1.8.3 (Windows 7), Board: "Arduino Due (Programming Port)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ulrich\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ulrich\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ulrich\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -ide-version=10803 -build-path C:\Users\ulrich\AppData\Local\Temp\arduino_build_782941 -warnings=none -build-cache C:\Users\ulrich\AppData\Local\Temp\arduino_cache_883209 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ulrich\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ulrich\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ulrich\Documents\Arduino\libraries -fqbn=arduino:sam:arduino_due_x_dbg -ide-version=10803 -build-path C:\Users\ulrich\AppData\Local\Temp\arduino_build_782941 -warnings=none -build-cache C:\Users\ulrich\AppData\Local\Temp\arduino_cache_883209 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1 -prefs=runtime.tools.bossac.path=C:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'arduino_due_x_dbg' from platform in folder: C:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11
Using core 'arduino' from platform in folder: C:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11
Detecting libraries used...
"C:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10803 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON '-DUSB_MANUFACTURER="Arduino LLC"' '-DUSB_PRODUCT="Arduino Due"' "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/libsam" "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/CMSIS/Include/" "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/Device/ATMEL/" "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino" "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\variants\arduino_due_x" "C:\Users\ulrich\AppData\Local\Temp\arduino_build_782941\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -nostdlib -fno-threadsafe-statics --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -Dprintf=iprintf -w -x c++ -E -CC -mcpu=cortex-m3 -mthumb -DF_CPU=84000000L -DARDUINO=10803 -DARDUINO_SAM_DUE -DARDUINO_ARCH_SAM -D__SAM3X8E__ -mthumb -DUSB_VID=0x2341 -DUSB_PID=0x003e -DUSBCON '-DUSB_MANUFACTURER="Arduino LLC"' '-DUSB_PRODUCT="Arduino Due"' "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/libsam" "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/CMSIS/Include/" "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\system/CMSIS/Device/ATMEL/" "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\cores\arduino" "-IC:\Users\ulrich\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\variants\arduino_due_x" "C:\Users\ulrich\AppData\Local\Temp\arduino_build_782941\sketch\Blink.ino.cpp" -o "C:\Users\ulrich\AppData\Local\Temp\arduino_build_782941\preproc\ctags_target_for_gcc_minus_e.cpp"
arm-none-eabi-g++: error: CreateProcess: No such file or directory
exit status 1
Error compiling for board Arduino Due (Programming Port).
