Arduíno Due Compilation Error
Hello
I'm trying to compile code for my Arduino Due, but it doesn't compile at all. What could it be? All help will be welcome.
My Code:
#include "FPS_GT511C3.h"
#include "SoftwareSerial.h"
FPS_GT511C3 fps(4, 5); // (Arduino SS_RX = pin 4, Arduino SS_TX = pin 5)
  Serial.begin(9600); //set up Arduino's hardware serial UART
  fps.UseSerialDebug = true; // so you can see the messages in the serial debug screen
  fps.Open(); //send serial command to initialize fps
  // FPS Blink LED Test
  fps.SetLED(true); // turn on the LED inside the fps
  fps.SetLED(false);// turn off the LED inside the fps
Error message:
Arduino: 1.8.10 (Windows 10), Board: "Arduino Due (Programming Port)"
In file included from C:\Users\Peace and Love\Desktop\Fingerprint\Fingerprint.ino:1:0:
C:\Program Files (x86)\Arduino\libraries\Fingerprint_Scanner-TTL-master\src/FPS_GT511C3.h:13:28: fatal error: SoftwareSerial.h: No such file or directory
compilation terminated.
Multiple libraries were found for "FPS_GT511C3.h"
 Used: C:\Program
exit status 1
Error compiling for board Arduino Due (Programming Port).
option enabled in File -> Preferences.
Thak You
This library is not for the DUE.
There are 5 hardware Serial, no need for a software serial.
However, FYI, antodom has provided a software serial for the DUE when more than 5 serial commmunications are needed.
