Arduino Due connection to Simulink error
Greetings,
I have been attempting to get my Arduino Due board to generate a signal I have designed using Simulink but I am getting some sort of connection error. I borrowed an Arduino Uno board and that connected fine but the Due is giving me an error. Part of the time, it tells me that arm-non-eabi-gcc.exe is not found as well. The error has been listed below. I've seen a post on Mathworks where someone had the same error but it was never resolved on the forum. I have a Window7 system.
The call to realtime_make_rtw_hook, during the after_make hook generated the following error:
    The build failed with the following message: "C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/tools/g++_arm_none_eabi/bin/arm-none-eabi-gcc" -I"C:/MATLAB/SupportPackages/R2014a/arduino/include" -I"C:/MATLAB/SupportPackages/R2014a/arduino/blocks/sfcn/include" -I"C:/Users/Elizabeth/Documents/MATLAB/untitled_rtt" -I"C:/Users/Elizabeth/Documents/MATLAB" -I"C:/Program Files/MATLAB/R2014a/extern/include" -I"C:/Program Files/MATLAB/R2014a/simulink/include" -I"C:/Program Files/MATLAB/R2014a/rtw/c/src" -I"C:/Program Files/MATLAB/R2014a/rtw/c/src/ext_mode/common" -I"C:/Program Files/MATLAB/R2014a/rtw/c/ert" -I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/system/libsam" -I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/system/CMSIS/CMSIS/Include" -I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/system/CMSIS/Device/ATMEL" -I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/cores/arduino" -I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/cores/arduino/USB" -I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/hardware/arduino/sam/variants/arduino_due_x" -I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/libraries/Servo/src" -I"C:/MATLAB/SupportPackages/R2014a/arduino-1.5.6-r2/libraries/Servo/src/sam" -c -g -Os -w -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -mcpu=cortex-m3 -mthumb -I. -D"MODEL=untitled" -D"NUMST=1" -D"NCSTATES=0" -D"HAVESTDIO=" -D"ONESTEPFCN=0" -D"TERMFCN=1" -D"MAT_FILE=0" -D"MULTI_INSTANCE_CODE=0" -D"INTEGER_CODE=0" -D"MT=0" -D"CLASSIC_INTERFACE=0" -D"ALLOCATIONFCN=0" -D"TID01EQ=0" -D"printf=iprintf" -D"F_CPU=84000000" -D"_RUNONTARGETHARDWARE_BUILD_=" -D"_ROTH_DUE_=" -D"ARDUINO=154" -D"ARDUINO_SAM_DUE=" -D"ARDUINO_ARCH_SAM=" -D"__SAM3X8E__=" -D"USB_PID=0x003e" -D"USB_VID=0x2341" -D"USBCON=" -D"_RTT_NUMSERVOS_=0"  ./IPAddress.cpp ./Print.cpp ./Reset.cpp ./RingBuffer.cpp ./Stream.cpp ./UARTClass.cpp ./USARTClass.cpp ./CDC.cpp ./HID.cpp ./USBCore.cpp ./WInterrupts.c ./WMath.cpp ./WString.cpp ./cortex_handlers.c ./cxxabi-compat.cpp ./hooks.c ./iar_calls_sam3.c ./itoa.c ./syscalls_sam3.c ./wiring.c ./wiring_analog.c ./wiring_digital.c ./wiring_pulse.cpp ./wiring_shift.c ./variant.cpp ./io_wrappers.cpp ./ert_main.c ./untitled.c ./untitled_data.c
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
cs-make: *** [IPAddress.o] Error 255
The build process will terminate as a result.
Any help would be greatly appreciated.
If you really believed that, you'd have posted in the Due part of the forum.
