arduino due control ai motor's
Dear friends,
My use arduino due I / O for TX0 & RX0
Here is my program
int led = 13;
int id;          // 馬達ID
int torg;        // 轉距(0:max, 4:min)
int checksum;    //  通訊協定
int tmp1, tmp2;  // byte  數量
  pinMode(led,OUTPUT);
  Serial.begin(115200);  // 起始串列115200bps
  while(!Serial){        // 等待通訊
  id = 0;
  torg = 2;  //  轉距速度
  digitalWrite(led,HIGH);
  tmp1 = (torg << 5) | id; //  馬達速度及編碼號
  tmp2 = 60;  // 位置碼
  checksum = (tmp1 ^ tmp2) & 0x7f; // 結束碼(馬達速度及編碼號XOR位置碼)
  Serial.write(0xff);   // 回傳編碼
  Serial.write(tmp1);
  Serial.write(tmp2);
  Serial.write(checksum);
  delay(5000);   // 等待時間
  tmp1 = (torg << 5) | id;   //馬達速度及編碼號
  tmp2 = 100;   //位置碼
  checksum = (tmp1 ^ tmp2) & 0x7f;  //結束碼(馬達速度及編碼號XOR位置碼)
  Serial.write(0xff);   //回傳編碼
  Serial.write(tmp1);
  Serial.write(tmp2);
  delay(1000); //等待時間
  digitalWrite(led,LOW);
  tmp2 = 200;
  Serial.write(0xff);
  Serial.write(tmp1);
  Serial.write(tmp2);
  tmp2 = 180;
  Serial.write(0xff);
  Serial.write(tmp1);
  Serial.write(tmp2);
  tmp2 = 220;
  Serial.write(0xff);
  Serial.write(tmp1);
  Serial.write(tmp2);
Ai motor have four pins inside the motor (V, TX, RX, G)
Motor TX → DUE RX0
Motor reception → DUE TX0
AI motor it can control, but not control another one
How do I modify my program use to DUE another pin for TX1, RX1, TX2, RX2, RX3, TX3 (pin)
I have 4 AI motor control
How to do modify to control 4 ai motor and use all TX RX pin?
What have you tried? If Serial talks to TX0 and RX0, what do you suppose that Serial1, Serial2, and Serial3 talk to?
