Hello all. I have a question about saving arrays to the internal flash. My sketch was to save an array of 50,000 samples from the ADC as an integer array.
Using 12bit resolution, that gives me about 100Kb to be on the safe side.
The sketch itself is only about 25.3Kb.
That should leave about 400Kb untouched. However, when I upload it, it crashes.
I was guessing that part of the sketch got written over by the array. Is this possible? And if so, how do I avoid this?
Here is my code.
10-25-14
Samples and plays back an incoming audio signal at 12 bit resolution
Mode 1 - Sampled audio is immediately played back through the DAC. Sampled audio is simultaneously
stored in a 20,000 sample array for playback later.
Mode 2 - Saved data is played back through the DAC in a loop.
Selection between modes is determined by the ADC value of the incoming audio
const int analogInPin = A1; // Audio in
const int analogOutPin = DAC0; // Audio out
pinMode (A1, INPUT);
pinMode (53, OUTPUT); // Lights an LED when in mode 2
analogReadResolution(12);
analogWriteResolution(12);
int sensorValue; // value read from the ADC
int savedData[20000]; //int array to save incoming samples
int dataPointer = 0;
while (true)
dataPointer = 0; //reset the pointer
digitalWrite (53, LOW); //turn off the LED
sensorValue = analogRead(analogInPin);
if (sensorValue < 125)
for (dataPointer = 0; dataPointer< sizeof(savedData); dataPointer++)
sensorValue = analogRead(analogInPin); //ADC input
analogWrite (DAC0, sensorValue * 3); //play on output amplify by 3
savedData[dataPointer] = sensorValue; //Also save in the array
else if (sensorValue > 125)
digitalWrite (53, HIGH); //Turn on the LED
analogWrite(DAC0, savedData[dataPointer] * 3);
delay (.5); //can insert a delay here for a cool effect
Thanks in advance for any help. Cheers.
P.S. Sorry about the code being split up. Not sure what happened. It wont let me paste it as one code block.
quailquillz:
No. You need to understand that you are dealing with different types of memory in an Arduino (AVR or SAM/ARM based).
The sketch is in FlashROM, which is read-only once you have uploaded you sketch. It only (by default) contains code. Up to 512KB on an Arduino Due..
Your variables, which require writeable memory, as stored in SRAM, of which the Due has 96KB. Don't know off hand if you can actually use close to that amount as a single variable (minus the general overhead for libs, etc), but your array of 20,000 'int's will take up 80,000 bytes, as by default in a 32 bit processor, sizeof (int) is 4 bytes! That just doesn't fly!
One way how you possibly can get away with this, as you say you are using only 12bit samples, is to explicitly define the array as of type "int_16". That would make above mentioned 20,000 entries large array only 40,000 bytes in size, which would even fit into the 64KB bank of SRAM...
--- good thought.
To the OP, how would the compiler even know you want your samples to go into FLASH?
When you declare an array of type int, it will take that from RAM, aka Variable Space.
I don't know of any "Arduino" way of putting data in FLASH, I would think it takes longer to write to FLASH than RAM, so that delay consideration isn't in the IDE (that I know of).
The point is that you can not "write to Flash". It requires a special write mode, which simply is not available during program/sketch execution. That's why it is called "FlashROM", contrary to "FlashRAM"...
On an ARM using "const" should place a variable in flash and not copy it to RAM, but as has been noted the problem here is that the array is too large for RAM.
