Hi All, I am currently playing with an Arduino Due, and after going through some tutorials, I am able to use analogwrite() function to generate PWM signal with different duty cycle, the following is my code, while I am not sure how can I change its default frequency to a different value, it will be really great if anyone could help me to add a few lines of code to change the PWM frequency.
int Output = 3; // Output chosen as digital pin 9
int analogPin = A2; // Analog input connected to analog pin 2
int val = 0; // variable to store the read value
int Mapvalue = 0;
int DutyCycle;
int MappedDC; //mapped duty cycle
pinMode(Output, OUTPUT); // sets the pin as output
DutyCycle=20;
MappedDC = map(DutyCycle,0,100,0,255);
val = analogRead(analogPin); // read the input pin
analogWrite(Output,MappedDC); // analogRead values go from 0 to 1023, analogWrite values from 0 to 255, if 255 means 100% duty cycle
Mapvalue=map(val,0,1023,0,255);
Serial.print(val);
