Arduino Due DAC output to powered speakers
I am trying to output sine waves to some powered speakers. I am aware that I need to do some sort of impedance matching but I'm not entirely clear on what I need to do to achieve that.
The measured input impedance of the speakers that I am using (an old boombox, with RCA inputs) is 53kohm. I ruined one of the DACs on another board trying to hook up the DAC directly to one of the channels through the RCA input so I am a little hesitant to connect it now. Could someone please provide some guidance?
No you don't. Use resistor divider to bring signal down to 0-2V level, then run it thru a capacitor so the powered speaker input sees +/1V signal.
Look at my post "piano tones micros" to see how I did the same with a '1284P chip. The cap to provide AC coupling between the devices is the important part.
http://forum.arduino.cc/index.php?topic=179761.0
I used 10uF polarized caps, experiment and see what sounds good to you.
CrossRoads:
Thanks for your quick response. So I do not need to impedance match? Could you maybe explain why? I thought the output impedance of the Due's DACs is low and would need to match the high input impedance of the boombox?
Also, I assume the capacitor is to get rid of the DC sent to the speakers? The Due seems to already provide 0-2V range (but not +/-1V due to DC).
The Due is basically driving an open circuit with a 53K ohm load. 3.3V/53K is microamps of current. Signal to 5K/10K to Gnd resistor divider to bring level down to 0-2.2V will be all the "matching" needed. If it's already 0-2V, then perhaps just a 10K to Gnd to make sure the signal doesn't float during resets or similar.
Yes, cap gets rid of DC and makes it a +/- signal with 0V ground.
CrossRoads: The Due is basically driving an open circuit with a 53K ohm load. 3.3V/53K is microamps of current. Signal to 5K/10K to Gnd resistor divider to bring level down to 0-2.2V will be all the "matching" needed. If it's already 0-2V, then perhaps just a 10K to Gnd to make sure the signal doesn't float during resets or similar.
Ok, that seems to make sense. I tried hooking up a 0.1uF cap in series to the DAC and tha got rid of the DC. I am still hesitant to connect it to the speakers because I seemed to ruined one of my DACs on a previous board by connecting it to the boombox without anything between the DACs and RCA inputs. Was it the DC that ruined the DAC?
Thanks for your help.
Probably yes.
