I found this code on this page. It works. But it doesn't work anymore if I put an analogWrite in voidloop. How do I reset the DAC?
#define NWAVE 80
uint16_t Sinewave[2][NWAVE] = {
+4095, +4093, +4089, +4081, +4070, +4056, +4038, +4018, +3995, +3968, +3939, +3907, +3872, +3834, +3793, +3750,
+3704, +3656, +3605, +3551, +3495, +3438, +3377, +3315, +3251, +3185, +3118, +3048, +2977, +2905, +2831, +2757,
+2681, +2604, +2526, +2447, +2368, +2289, +2209, +2128, +2048, +1968, +1887, +1807, +1728, +1649, +1570, +1492,
+1415, +1339, +1265, +1191, +1119, +1048, +978, +911, +845, +781, +719, +658, +601, +545, +491, +440,
+392, +346, +303, +262, +224, +189, +157, +128, +101, +78, +58, +40, +26, +15, +7, +3,
+1, +3, +7, +15, +26, +40, +58, +78, +101, +128, +157, +189, +224, +262, +303, +346,
+392, +440, +491, +545, +601, +658, +719, +781, +845, +911, +978, +1048, +1119, +1191, +1265, +1339,
+1415, +1492, +1570, +1649, +1728, +1807, +1887, +1968, +2048, +2128, +2209, +2289, +2368, +2447, +2526, +2604,
+2681, +2757, +2831, +2905, +2977, +3048, +3118, +3185, +3251, +3315, +3377, +3438, +3495, +3551, +3605, +3656,
+3704, +3750, +3793, +3834, +3872, +3907, +3939, +3968, +3995, +4018, +4038, +4056, +4070, +4081, +4089, +4093
uint16_t SineFast[2][NWAVE] = {
+4095, +3939, +3495, +2831, +2048, +1265, +601, +157, +1, +157, +601, +1265, +2048, +2831, +3495, +3939,
int fast_mode = 0;
int freq_inhz = 1000; // Default Hz
int freq_intc = 0;
int user_intf = 0;
volatile uint16_t sptr = 0;
Serial.begin (115200);
dac_setup();
freq_intc = freqToTc(freq_inhz);
TC_setup();
setup_pio_TIOA0();
int tcToFreq( int tc_cntr)
int freq_hz;
if( tc_cntr == 0 ) return 1000;
if( fast_mode ) freq_hz = (420000000UL / tc_cntr) / (2 * NWAVE);
else freq_hz = ( 42000000UL / tc_cntr) / (2 * NWAVE);
return freq_hz;
int freqToTc( int freq_hz)
int tc_cntr = 0;
if( freq_hz == 0 ) return 25;
if( fast_mode ) tc_cntr = (420000000UL / freq_hz) / (2 * NWAVE);
else tc_cntr = ( 42000000UL / freq_hz) / (2 * NWAVE);
return tc_cntr;
void switch_mode( int mode)
if( mode == 0 )
DACC->DACC_TPR = (uint32_t) Sinewave[0]; // DMA buffer
DACC->DACC_TCR = NWAVE;
DACC->DACC_TNPR = (uint32_t) Sinewave[1]; // next DMA buffer
DACC->DACC_TNCR = NWAVE;
DACC->DACC_TPR = (uint32_t) SineFast[0]; // DMA buffer
DACC->DACC_TNPR = (uint32_t) SineFast[1]; // next DMA buffer
char in_Byte;
int temp;
if (Serial.available() > 0) {
in_Byte = Serial.read();
// Message Format To Set Frequency: 1000f + "send".
if((in_Byte >= '0') && (in_Byte <= '9'))
user_intf = (user_intf * 10) + (in_Byte - '0');
if (in_Byte == 'f') // end delimiter
if ((user_intf > 20) && (user_intf < 100000))
freq_inhz = user_intf;
if( freq_inhz > 10000 ) temp = 1;
else temp = 0;
if (temp != fast_mode)
fast_mode = temp;
switch_mode(fast_mode);
TC_setup();
Serial.print("Fast Mode = ");
Serial.println(fast_mode, DEC);
Serial.print("freq_inhz = ");
Serial.println(freq_inhz, DEC);
Serial.print("freq_intc = ");
Serial.println(freq_intc, DEC);
Serial.print("approximation = ");
temp = tcToFreq(freq_intc);
Serial.println(temp, DEC);
user_intf = 0; // reset to 0 ready for the next sequence of digits
void DACC_Handler(void)
if((dacc_get_interrupt_status(DACC) & DACC_ISR_ENDTX) == DACC_ISR_ENDTX) {
++sptr;
sptr &= 0x01;
if(fast_mode == 0)
DACC->DACC_TNPR = (uint32_t) Sinewave[sptr]; // next DMA buffer
DACC->DACC_TNPR = (uint32_t) SineFast[sptr]; // next DMA buffer
void setup_pio_TIOA0()
PIOB->PIO_PDR = PIO_PB25B_TIOA0;
PIOB->PIO_IDR = PIO_PB25B_TIOA0;
PIOB->PIO_ABSR |= PIO_PB25B_TIOA0;
void TC_setup ()
pmc_enable_periph_clk(TC_INTERFACE_ID + 0 *3 + 0);
TcChannel * t = &(TC0->TC_CHANNEL)[0];
t->TC_CCR = TC_CCR_CLKDIS;
t->TC_IDR = 0xFFFFFFFF;
t->TC_SR;
t->TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK1 |
TC_CMR_WAVE |
TC_CMR_WAVSEL_UP_RC |
TC_CMR_EEVT_XC0 |
TC_CMR_ACPA_CLEAR | TC_CMR_ACPC_CLEAR |
TC_CMR_BCPB_CLEAR | TC_CMR_BCPC_CLEAR;
t->TC_RC = freq_intc;
t->TC_RA = freq_intc /2;
t->TC_CMR = (t->TC_CMR & 0xFFF0FFFF) | TC_CMR_ACPA_CLEAR | TC_CMR_ACPC_SET;
t->TC_CCR = TC_CCR_CLKEN | TC_CCR_SWTRG;
void dac_setup ()
pmc_enable_periph_clk (DACC_INTERFACE_ID) ; // start clocking DAC
dacc_reset(DACC);
dacc_set_transfer_mode(DACC, 0);
dacc_set_power_save(DACC, 0, 1); // sleep = 0, fastwkup = 1
dacc_set_analog_control(DACC, DACC_ACR_IBCTLCH0(0x02) | DACC_ACR_IBCTLCH1(0x02) | DACC_ACR_IBCTLDACCORE(0x01));
dacc_set_trigger(DACC, 1);
// dacc_set_channel_selection(DACC, 1);
//dacc_enable_channel(DACC, 1);
dacc_set_channel_selection(DACC, 0);
dacc_enable_channel(DACC, 0);
NVIC_DisableIRQ(DACC_IRQn);
NVIC_ClearPendingIRQ(DACC_IRQn);
NVIC_EnableIRQ(DACC_IRQn);
dacc_enable_interrupt(DACC, DACC_IER_ENDTX);
DACC->DACC_PTCR = 0x00000100; //TXTEN - 8, RXTEN - 1.
